Cisco Call Manager Configuration
5. Fax
6. Voicemail
7. Outbound Dialing
Outbound VoIP calls
External Database Source (v7)
8. Speech Recognition
9. Logs
10. ActiveX / COM Interface
11. PBX Integration (CTI)
It is sometimes desirable to carry out some processing before the call is answered. Quite often the purpose of this processing is to determine whether the call should be answered or not at all.
A VoiceGuide script can be configured to start running without answering the telephone line. This allows VoiceGuide to conduct any Caller ID based database lookups or calls to users programs, VB Script calls etc. in order to determine how the call should be treated.
To select this option use the "Script Properties" menu entry from the "Edit" menu in the Graphical Design Environment, then check the "Start the script without answering call" box.
For a given script to answer all incoming calls leave the "Start the script without answering call" box unchecked (this is the default setting for each new script).
Modules allowed before the call is answered
The following modules can be used:
  Make Call
  Hangup the Call
Arriving at the "Hangup Call" module results in the script finishing and the call never being answered.
Answering the call
Calling any module which plays or records a sound file or transfers the call will result in a call being answered.
Reaching the following modules in the script will effectively answer the call:
Play Sound File
Record Sound File
Get Number
Say Number
Converted from CHM to HTML with chm2web Pro 2.84 (unicode)
