Commanlink In Vg7 Hmp
Hello,
I have a VB script that look for the voice files in the set VG = CreateObject("VoiceGuide.CommandLink".
I am using VG7 with HMP driver. would this version of the VG works with above command?
Farzad
You need the Enterprise (or Evaluation) version of VoiceGuide to use the CreateObject("VoiceGuide.CommandLink") command.
If you a are using Enterprise version of VoiceGuide and are having problems running the CreateObject("VoiceGuide.CommandLink") command then please post the vgEngine trace capturing the call. We can then see what is happening on the system.
Hello,
I am using the evaluation version of the VG7 HMP. my VBS running the voice file from VG system\voice file. I am trying to play numbers in multi languages.
Since I am testing the VG7 HMP, would you please let me know what technique should I use to link in my scrip to my voice file (which are the voice of numbers) in system\voice?
