New Instalation Not Working.
In completely new server with windows 7 not working script.
log file:
162401.490 6 11 4 FindNextVgmTitleInPathList: next module title is=[ustal DDI]
162401.490 6 11 4 matching path found (Boolean True)
162401.490 6 11 4 t timer clear (force=False)
162401.490 6 11 4 RunModule start Evaluate, [ustal DDI], iModuleIdx=107, previous: vgm=149, vgs=2:2
162401.490 6 11 4 state [ustal DDI] Evaluate [$RV_CIDNUMBER]
162401.490 6 11 4 rv replace start [$RV_CIDNUMBER]
162401.490 6 11 4 rv replace end [222030034]
162401.491 6 11 4 eval [222030034]
162401.491 6 11 4 eval InvokeMember Eval returned
162401.491 6 11 4 d added ustal DDI_Input | 222030034
162401.491 6 11 4 d added ustal DDI | 222030034
162401.491 6 11 4 creating new (non-global) rv : NUMER_DDI
162401.491 6 11 4 d added NUMER_DDI | 222030034
162401.491 6 11 4 Eval Expr result:[222030034] stored in RV[NUMER_DDI]
162401.491 6 11 4 path {222030034} found (at offset 3)
162401.491 6 11 4 FindNextVgmTitleInPathList: next module title is=[Get Numbers 1]
162401.491 6 11 4 t timer clear (force=False)
162401.491 6 11 4 RunModule start Get Numbers, [Get Numbers 1], iModuleIdx=106, previous: vgm=107, vgs=2:2
162401.492 6 11 4 state [Get Numbers 1] Number Input
162401.492 6 11 4 answering the call (picking up the line)
162401.492 6 11 4 t timer clear (force=True)
162401.492 6 11 4 ktTel_AnswerCall_Enqueue source=AnswerTheCall
162401.492 6 11 4 q tel add cmd_AnswerCall [0,0,0,0,0][||||]
162401.492 6 11 4 ktTel_LineAnswerCall =>
162401.492 7 q tel max count 1
162401.492 6 11 4 q scr run evCallState sCode=[GCEV_DISCONNECTED] iActionID=0, crn=2800004[16384|0|64|0|0][|||||] 00:00:00.0030002 max:6|00:00:00.0730041
162401.492 7 q tel max time 00:00:00
162401.492 6 11 4 LineEvCallState crn=2800004 event=2|GCEV_DISCONNECTED iCallState=16384 calldirection=0 gcCallState=64 [||]
162401.492 7 11 4 q tel run cmd_AnswerCall 00:00:00 max:1|00:00:00
162401.492 6 11 4 LineEvCallState eLineStateThisEvent=Disconnected, ScriptState=LS_MODULE_TRANSITION
162401.492 6 11 4 HangupCall, source=LINECALLSTATE_DISCONNECTED, WorkModeScript=Running_BeforeAnswerCall, yLineStateAppPov=[Offered], lPlayId=0, lRecId=0
162401.492 6 11 4 moduleTitle=[Get Numbers 1]
162401.492 6 11 4 ScriptWorkingMode set Stopping, (called from HangupCall)
162401.492 6 11 4 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL)
162401.493 6 11 4 ls set ignore new linestate set as current linestate is Offered
162401.493 6 11 4 state Hanging up... [LINECALLSTATE_DISCONNECTED]
162401.493 6 11 4 rv add [Hangup Source]{LINECALLSTATE_DISCONNECTED}
162401.493 6 11 4 d added Hangup Source | LINECALLSTATE_DISCONNECTED
162401.493 6 11 4 GoOnHoook_IssueDropCall start (hCall_crn=2800004, yLineStateAppPov=Offered)
162401.493 6 11 4 WriteToLogFiles_CurrScriptOnly begin
162401.493 6 11 4 WriteToLogFiles_DoWrite begin : strLogFnameLessSuffix=C:\Program Files (x86)\VoiceGuide\Scripts\Maciej\prepaid_2011_10_14
162401.493 6 11 4 WriteToLogFiles_DoWrite : log subdirectory exists, strLogFnameLessSuffix=C:\Program Files (x86)\VoiceGuide\Scripts\Maciej\log\prepaid_2011_10_14
162401.494 6 11 4 WriteToLogFiles_DoWrite completed
162401.494 6 11 4 RvSaveToLogFiles_CurrAndStack iScriptCallStack_LastUsed_Idx=0
162401.494 6 11 4 t timer set 4 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall
162401.494 6 11 4 q tel add cmd_DropCall [0,0,0,0,0][||||]
162401.494 6 11 4 GoOnHoook_IssueDropCall end
162401.494 6 11 4 ls set Disconnected (scriptstate=LS_ENDINGCALL)
162401.495 6 11 4 ls set ignore new linestate set as current linestate is Offered
162401.495 6 11 4 yLineStateAppPov: Offered crn=2800004,ev=2,GCEV_DISCONNECTED,0, sParam1=
162401.495 7 q tel max time 00:00:00.0010001
162401.495 7 11 4 q tel run cmd_DropCall 00:00:00.0010001 max:1|00:00:00.0010001
162401.495 6 11 4 LineEvCallState LINECALLSTATE_DISCONNECTED begin
162401.495 6 11 4 in LINECALLSTATE_DISCONNECTED iState=LS_ENDINGCALL
162401.495 6 11 4 q scr add evScriptEvent 9250 DISCONNECTED
162401.495 6 11 4 q scr run evScriptEvent sCode=[DISCONNECTED] iActionID=0, crn=0[0|64|0|0|0][|||||] 00:00:00 max:6|00:00:00.0730041
162401.495 6 11 4 scriptevent DISCONNECTED 0|64|0 || LineState=LS_ENDINGCALL
162401.495 6 11 4 LsEndingCall DISCONNECTED 0
162401.504 18 11 4 ev CallState GCEV_DROPCALL, crn=2800004, iEvent=2 ,1,0,32, s1:, s2:, s3:]. build_date: 2013-03-30 21:24:51.06
162401.504 18 11 4 q scr add evCallState 2 GCEV_DROPCALL
162401.504 6 q scr max count 1
162401.504 6 q scr max time 00:00:00
162401.504 6 11 4 q scr run evCallState sCode=[GCEV_DROPCALL] iActionID=0, crn=2800004[1|0|32|0|0][|||||] 00:00:00 max:1|00:00:00
162401.504 6 11 4 LineEvCallState crn=2800004 event=2|GCEV_DROPCALL iCallState=1 calldirection=0 gcCallState=32 [||]
162401.504 6 11 4 LineEvCallState eLineStateThisEvent=Idle_NotYetReleased, ScriptState=LS_ENDINGCALL
162401.504 6 11 4 ls set Idle_NotYetReleased (scriptstate=LS_ENDINGCALL)
162401.504 6 11 4 ls set ignore new linestate set as current linestate is Offered
162401.504 6 11 4 yLineStateAppPov: Offered crn=2800004,ev=2,GCEV_DROPCALL,0, sParam1=
162401.504 6 11 4 LineEvCallState LINECALLSTATE_IDLE begin
This same script in other machine working properly.
ISDN operation needs to be first confirmed with Dialogic's isdiag before proceeding with installing VoiceGuide
Please see: hhttp://www.voiceguide.com/vghelp/source/html/configisdnsetup.htm
Uninstall VoiceGuide and use isdiag to answer incoming call on system. You can use isdiag to play a sound file and confirm caller can hear the sound file as well.
Use isdiag to capture the ISDN trace of call being answered and sound file played, and post that ISDN trace here.
Please .ZIP up any traces before posting.
