Fritz!x
Hello
Has anybody got call transfer working on the Fritz!X usb modem?
I am trying to get at call transfered from an incomming ISDN line, to one of the analog extensions on the modem. It should support PBX, but i simply cant get the damn thing to transfer anything...
Please Help
Jon Leren Schøpzinsky
Can you plz describe your system configuration in more detail... (is the modem attached to the Fritz!X usb?)
Im having exactly the same problem. Im trying Voiceguide with my Fritz!X usb 3.0 and even though it picks up the call and plays a welcome message, when it's supposed to do a blind transfer call to any analog extension, it doesn't work. The call hangs up automatically after some seconds. In the PBX properties in the script editor wverything seems to be configured properly, since the "!" it's said to be be the hookflash and with the FRITZ!X you transfer a call by pressing the hookflash and the extension number. Could you please help me? If this works, I will definitely buy Voiceguide, but I need it to work urgently.
Thank you. Hernán Chapnik
Hookflash transfers are only used on analog lines.
Are you using one of the analog extensions on the Fritz!X switch?
What telephony device are you using to attach to the Fritz!X switch? Is it a Dialogic card?
If the call is hung up without the caller hearing any DTMF tones being played then most likely that hookflash length on the telephony device is too long. Instructions on how to change the hookflash length are in this section of the Help file: http://www.voiceguide.com/vghelp/source/ht...lltransfers.htm
This is what I get in the log. The call hangs up when it's supposed to transfer the call.
175116,09 15 tapi callstate OFFERING 65587 1 4
175116,09 15 rv clear
175116,09 15 Start without answering the call
175116,09 15 startLoadedVgs at 18/07/2007 17:51:16, script interpretor VgMulti v5.2.5049 0
175116,09 15 rv ns add [scriptsPath]{C:\Documents and Settings\Burbujas\Escritorio\}
175116,09 15 rv ns add [scriptPath]{C:\Documents and Settings\Burbujas\Escritorio}
175116,10 15 rv lg add [$RV_STARTTIME]{18/07/2007 17:51:16}
175116,10 15 rv lg add [$RV_DEVICEID]{15}
175116,10 15 rv lg add [$RV_CIDNAME]{}
175116,10 15 rv ns add [PathApp]{C:\Archivos de programa\VoiceGuide\}
175116,10 15 rv lg add [$RV_CIDNUMBER]{}
175116,11 15 rv lg add [$RV_DNIS]{}
175116,11 15 rv lg add [DNIS]{}
175116,11 15 timer clear
175116,12 15 state [Record 3] Recording
175116,12 15 lineAnswer(65587) => 65570
175116,12 15 ev Lev_CallerID [914038833,,914038833]
175116,13 15 tapi callstate ACCEPTED 65587 0 0
175116,14 15 tapi Reply (LineEvReply) ok 65570 0 LineCallState=ACCEPTED
175116,23 dial start any summary:|15:hc>0|16:idx=0|
175116,61 15 tapi callstate CONNECTED 65587 1 0
175116,62 15 callstate CONNECTED 65587,1,0
175116,63 15 WorkingModeTAPI@Connected=
175116,63 15 WorkingModeScript@Connected=BeforeAnswerRun
175116,64 15 Inband detection not enabled
175116,64 15 timer clear
175116,65 15 state [Record 3] Recording
175116,66 15 rv replace start: [$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav]
175116,66 15 rv ns [PathSysVoice]{C:\Archivos de programa\VoiceGuide\system\voice\}[PathApp]{C:\Archivos de programa\VoiceGuide\}[PathDataVm]{C:\Archivos de programa\VoiceGuide\data\}[PathVgSys]{C:\Archivos de programa\VoiceGuide\system\}[scriptsPath]{C:\Documents and Settings\Burbujas\Escritorio\}[scriptPath]{C:\Documents and Settings\Burbujas\Escritorio}[$RV_STARTTIME]{18/07/2007 17:51:16}[$RV_DEVICEID]{15}[$RV_CIDNAME]{}[PathApp]{C:\Archivos de programa\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}
175116,67 15 rv replace end: [914038833__0718_175116.wav]
175116,67 15 rv lg add [Record 3]{C:\Documents and Settings\Burbujas\Escritorio\914038833__0718_175116.wav}
175116,68 15 RecSoundStart file[C:\Documents and Settings\Burbujas\Escritorio\914038833__0718_175116.wav] ok
175116,69 15 eng RecSoundStart [C:\Documents and Settings\Burbujas\Escritorio\914038833__0718_175116.wav]
175116,70 15 timer set 5 EV_TIMEOUT_GOTOMODULE
175121,61 15 timer fired EV_TIMEOUT_GOTOMODULE
175121,61 15 ScriptEventCode 9002 iLineState=1201
175121,62 15 LsRecRecording EV_TIMEOUT_GOTOMODULE
175121,63 15 RecSoundStop ok
175121,63 15 rec length RV: Record 3_RecLen100ms = 48
175121,64 15 rv lg add [Record 3_RecLen100ms]{48}
175121,65 15 rv lg add [Record 3_EndRecCause]{timeout}
175121,65 15 ScriptEventCode 8003 iLineState=5900
175121,66 15 timer clear
175121,67 15 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
175122,08 15 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
175122,09 15 ScriptEventCode 9012 iLineState=1900
175122,09 15 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
175122,10 15 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
175122,11 15 state [Transfer Call 1] Blind Transfer to 2 (Generate)
175122,12 15 tapic lineGenerateDigits(65587 [!] 100) => ok
175122,12 15 generate LINEGENERATETERM_CANCEL
175122,13 15 timer set 1 EV_TAPI_GENERATE
175123,12 15 timer fired EV_TAPI_GENERATE
175123,12 15 ScriptEventCode 9602 iLineState=1900
175123,13 15 LsXferStart EV_TAPI_GENERATE
175123,13 15 timer set 1 EV_HOOKFLASHFINISHED
175124,14 15 timer fired EV_HOOKFLASHFINISHED
175124,14 15 ScriptEventCode 9200 iLineState=1905
175124,15 15 LsXferPlayVts EV_HOOKFLASHFINISHED
175124,16 15 tapic lineGenerateDigits(65587 [2] 100) => ok
175124,16 15 generate LINEGENERATETERM_DONE
175124,17 15 timer set 1 EV_TAPI_GENERATE
175125,16 15 timer fired EV_TAPI_GENERATE
175125,16 15 ScriptEventCode 9602 iLineState=1905
175125,17 15 LsXferPlayVts EV_TAPI_GENERATE
175125,18 15 timer set 3 EV_TIMEOUT_HANGUP
175128,20 15 timer fired EV_TIMEOUT_HANGUP
175128,20 15 ScriptEventCode 9001 iLineState=1905
175128,21 15 LsXferPlayVts EV_TIMEOUT_HANGUP
175128,21 15 rv lg add [Hangup Time]{18/07/2007 17:51:28}
175128,21 15 state Hanging up call...
175128,23 15 RecSoundStop ok
175128,23 15 PlaySoundStop err=0
175128,23 15 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
175128,25 15 fnHangupCall end
175128,54 15 tapi callstate DISCONNECTED 65587 1 0
175128,55 15 ScriptEventCode 9250 iLineState=900
175128,55 15 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
175128,56 15 rv lg add [Hangup Time]{18/07/2007 17:51:28}
175128,56 15 state Hanging up call...
175128,57 15 RecSoundStop ok
175128,58 15 PlaySoundStop err=0
175128,58 15 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
175128,59 15 fnHangupCall end
175128,59 15 tapi callstate IDLE 65587 0 0
175128,60 15 WorkingMode@Idle=
175128,60 15 timer clear
175128,61 15 WriteToLogFiles_CurrScriptOnly start
175128,61 WriteToLogFiles_DoWrite start (C:\Documents and Settings\Burbujas\Escritorio\dsa)
175128,62 15 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
175128,63 15 tapi Reply (LineEvReply) ok 66407 0 LineCallState=IDLE
175128,63 15 tapi Reply (LineEvReply) ok 66458 0 LineCallState=IDLE
175129,59 15 timer fired EV_TIMEOUT_TIMETOREINITLINE
175129,59 15 ScriptEventCode 9008 iLineState=900
175129,60 15 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
175129,60 15 ReinitTelephony due to IDLE
175129,61 15 tapic lineDeallocateCall(MainCall:65587) 0
175129,62 15 lineOpen(15)=>
175129,62 15 state Waiting for a call...
175129,64 15 LineHandle=66356
175129,64 15 ClearCallHandle called from ReinitAtIdle
175129,65 15 amchk set AMdet=False in Reinit@idle
175129,65 15 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
175130,39 dial start any summary:|15:rdy=0|16:idx=0|
175132,66 15 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
175132,66 15 ScriptEventCode 9013 iLineState=900
175133,43 dial start any summary:|15:idx=0|16:idx=0|
FRITZ!X is a PBX with the fritz!CARD into it. It's an isdn card and every extension is analog. Thus, im not using a Dialogic Card, it's an isdn board with a pbx included. It's not a regular analog modem, it includes many features very similar to dialogic board, however I don't know where to change the hookflash length for it.
I would very much appreciate your response as soon as possible.
Regards,
Hernán Chapnik.
Hernan: When VG for TAPI finds a "!" char, it simulates a flash-hook break using the TAPI 'Generate' function by default. For ISDN, you can reconfigure the tone-generation process to use true TAPI functions. When this is done, TAPI will do a proper 'blindTransfer' by controlling the ISDN connection directly using tapi function calls. To do this, you need to change some settings in the VG.INI file to 'TAPI' (which are set to 'GENERATE' by default). Sorry, I don't hae the exact details right now, but search the forum as I have posted this before. Also, your ISDN/Fritz/TSP(TAPI) driver needs to support line transfers to this to work. Only ISDN Blind-Transfers work, no other form of transfer works. (A Blind Transfer is essentially a digital equivalent of the analog flash-hook).
Dear ktruk: Thank u for your answer. Ill look for the vg.ini file and search for "GENERATE" and replace it with TAPI. Reagarding to the drivers, I updated from the AVM site the last TAPI, CAPI drivers for my Fritz!X. Do you know if this will word? Thank you in advanced again. Hernán
Hernan: Sorry, I do not know if Fritz drivers will definately work. You will have to try it. However, if it does not not work, since card is CAPI, you can also try ComISDN driver (see: www.comisdn.com) which may work. ComISDN is a CAPI<>TAPI driver. Often CAPI support is better than TAPI using cards own drivers. ComISDN is not free, but you can try 30 days. I have eicon BRI (S0) (and PRI) cards and comisdn doing blindLineTransfer no problem on Euro-ISDN lines and voiceguide for tapi. I also tried Fritz card with comisdn and it worked some 2 years ago, but did not try blindLineTransfer at that time. Good luck.
