Second Pri Channels Blocked
how to test channels starting 31 channel?
description suggest only 1-30 (isdiag 1 1 e s v)
what to use to confirm that second channel working? Witch option in isdiag menu?
Running isdiag.exe with no parameters will bring up the documentation. There is an option there to select the 'board number', and the channel on the 'board'.
First T1/E1 is board 1, second T1/E1 is board 2, etc.
