invoso.com Report post Posted 05/21/2012 10:01 AM Hello, Can You help me? I need to register calling number without answering call in VG. Share this post Link to post
SupportTeam Report post Posted 05/21/2012 12:21 PM VoiceGuide does not have to answer incoming calls to start running the script. Please see: http://www.voiceguide.com/vghelp/source/html/call%20start.htm A VoiceGuide script can be configured to start running without answering the telephone line. This allows VoiceGuide to conduct any Caller ID based database lookups or calls to users programs, VB Script calls etc. in order to determine how the call should be treated. ... Arriving at the "Hangup Call" module results in the script finishing and the call never being answered. Share this post Link to post
SupportTeam Report post Posted 05/21/2012 09:01 PM All that is required to enable the start without answering calls option is to check the "Start the script without answering call" box in the Script Properties window. To display Script Properties window: In Script Designer In the 'Edit' menu Select 'Script Properties' option Not sure how you want to register calling number. To just echo the CallerID number to a file and then end without answering the call a script like this would be used (view .vgs file in VoiceGuide Script Designer): LogCallerIDWithoutAnsweringCall.vgs Share this post Link to post
invoso.com Report post Posted 05/22/2012 08:00 AM How to decide witch script module should answer the call? (exclude script properties) I want to declare start module in script properties and other module to answer call (e.g. PLAY welcome). I need to analyze calling number before pick up the call. Share this post Link to post
SupportTeam Report post Posted 05/22/2012 09:31 AM The starting module(s) that look at the CallerID/DNIS and decide what to do next can just go to specific Play modules using Paths, or Script_Goto calls etc. eg. in starting modules you can do a database query that returns a result, and the value of the result can be used oin Evaluate Expression moudle to go to next module. See attached script (view .vgs file in VoiceGuide Script Designer): PlayGroupGreeting.vgs Share this post Link to post
invoso.com Report post Posted 05/22/2012 11:53 AM Question is: when Script pick up the call - start connection? I imagine in this case script that modules: Echo, DBquery and RouteOnGroup working when caller waiting on connection (calling signal) and in Play module Script starting connection. I need to prepare all data (db Querys) during calling ring and pick up in first PLAY module or other module I sign. Share this post Link to post
SupportTeam Report post Posted 05/22/2012 11:56 AM From http://www.voiceguide.com/vghelp/source/html/call%20start.htm : Answering the call Calling any module which plays or records a sound file or transfers the call will result in a call being answered. Reaching the following modules in the script will effectively answer the call: Play Sound File Record Sound File Get Number Say Number Transfer Call Share this post Link to post
