Vg Unexpected Disconnecting Call
Trace show that the Dialogic card reported that it received an ISDN message from Telco that the call has ended.
Message arrived on the channel of the incoming leg of the call.
072602.918 764 2 ev GCEV_DISCONNECTED crn=28401d2
072602.918 764 2 gc_ResultValue: event 0x826 received on ldev: 2 - Normal completion
072602.918 19 2 1 ev CallState GCEV_DISCONNECTED, crn=28401d2, iEvent=2 ,16384,0,64,,,]. vgEngine v7.3.4413.40408 (2012-01-31 22:26:55.92)
If you wish to independently confirm which end disconnected you can put an ISDN analyzer on the E1 trunk, or ask the Telco who they think disconnected that call.
It's also possible to enable ISDN tracing in Dialogic. (see: http://www.voiceguide.com/vghelp/source/html/configisdnsetup.htm section "VoiceGuide ISDN Tracing")
This ISDN tracing works in both VG v6 and VG v7. Note that ISDN level traces usually only capture the first few calls on the board.
In "Dial and Conference" tab option: Bridge calls together when: ... Ignore disconnect tones.
This option will ignore this kind of signals?
I turned it off to test, but will know that is right way.
In that option only the tones that are heard on the line are ignored. Its an option that only would be used on analog lines, where tones are used to advise call progress information.
If the ISDN message advising end of call is received, then this is a definitive indication that that call was ended.
There is nothing to be gained by ignoring that message. The call has ended.
I have new disconnection case:
135651.428 6 2 1 t timer set 60 sec : EV_TIMEOUT_REPLAYMSG
135735.100 17 2 1 ev Dialogic 134,TDX_CST, crn=2840104, 1000,0,0,DE_TONEON,DISCONNECT_USER_1,
135735.100 17 2 1 q scr add evScriptEvent 134 DISCONNECT
135735.100 17 2 1 q scr add evScriptEvent 134 DISCONNECT_USER_1
135735.100 6 2 1 q scr run evScriptEvent sCode=[DISCONNECT] iActionID=0, crn=2840104[1000|0|0|0|0][DE_TONEON|DISCONNECT_USER_1||||]
135735.100 17 2 1 q scr add evScriptEvent 134 TDX_CST
135735.100 6 2 1 scriptevent DISCONNECT 1000|0|0 DE_TONEON|DISCONNECT_USER_1|
135735.100 6 2 1 LsPlayMsgFinished EV_UNKNOWN_134,DISCONNECT, [DE_TONEON ], [DISCONNECT_USER_1 ], []
135735.100 17 2 1 ev CallState LINECALLSTATE_DISCONNECTED-DISCONNECT_USER_1, crn=2840104, iEvent=2 ,16384,0,64,,,]. vgEngine v7.3.4413.40408 (2012-01-31 22:26:55.92)
135735.100 6 2 1 path {DISCONNECT} not found
It should be interpreted as disconnection on USER 1 side?
Next case unexpected disconnecting:
183253.367 10 2 1 timer EV_TIMEOUT_REPLAYMSG
183253.367 10 2 1 q scr add evScriptEvent 9005 EV_TIMEOUT_REPLAYMSG
183253.367 6 2 1 q scr run evScriptEvent sCode=[EV_TIMEOUT_REPLAYMSG] iActionID=0, crn=0[0|0|0|0|0][|||||]
183253.367 6 2 1 scriptevent EV_TIMEOUT_REPLAYMSG 0|0|0 ||
183253.367 6 2 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG, [ ], [ ], []
183253.367 6 2 1 path {EV_TIMEOUT_REPLAYMSG} not found
183253.367 6 2 1 PrepareAndPlayWavAndTts start iModuleIdx=560, iPlayFileIdx=1, bMakeTtsFile=False, sSoundFileIs=
183253.367 6 2 1 PrepareAndPlayWavAndTTS sPlayFile=
183253.367 6 2 1 state [Wait till end of call,_91] Playing wav ()
183253.367 6 2 1 q scr add evScriptEvent 8001 EV_PLAY_FINISHED
183253.367 6 2 1 q scr run evScriptEvent sCode=[EV_PLAY_FINISHED] iActionID=0, crn=0[0|0|0|0|0][|||||]
183253.367 6 2 1 scriptevent EV_PLAY_FINISHED 0|0|0 ||
183253.367 6 2 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
183253.367 6 2 1 path {EV_PLAY_FINISHED} not found
183253.367 6 2 1 iCurrReplayCount=9, iMaxReplayCount=20
183253.367 6 2 1 t timer set 60 sec : EV_TIMEOUT_REPLAYMSG
183327.148 17 2 1 ev CallState GCEV_DISCONNECTED, crn=28401da, iEvent=2 ,16384,0,64,,,]. vgEngine v7.3.4413.40408 (2012-01-31 22:26:55.92)
183327.148 17 2 1 q scr add evCallState 2 GCEV_DISCONNECTED
183327.148 6 2 1 q scr run evCallState sCode=[GCEV_DISCONNECTED] iActionID=0, crn=28401da[16384|0|64|0|0][|||||]
183327.148 6 2 1 LineEvCallState crn=28401da event=2|GCEV_DISCONNECTED iCallState=16384 calldirection=0 gcCallState=64 [||]
183327.148 6 2 1 LineEvCallState eLineStateThisEvent=Disconnected, ScriptState=LS_PLAY_PLAYMSGFINISHED
183327.148 6 2 1 HangupCall, source=LINECALLSTATE_DISCONNECTED, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=664687
183327.148 6 2 1 moduleTitle=[Wait till end of call,_91]
183327.148 6 2 1 ScriptWorkingMode set Stopping, (called from HangupCall)
183327.148 6 2 1 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL)
183327.148 6 2 1 state Hanging up... [LINECALLSTATE_DISCONNECTED]
183327.148 6 2 1 rv add [Hangup Source]{LINECALLSTATE_DISCONNECTED}
183327.148 6 d added Hangup Source | LINECALLSTATE_DISCONNECTED | ( 48 61 6e 67 75 70 20 53 6f 75 72 63 65 | 4c 49 4e 45 43 41 4c 4c 53 54 41 54 45 5f 44 49 53 43 4f 4e 4e 45 43 54 45 44 | 77) id=2
183327.148 6 d added Hangup Source | LINECALLSTATE_DISCONNECTED | ( 48 61 6e 67 75 70 20 53 6f 75 72 63 65 | 4c 49 4e 45 43 41 4c 4c 53 54 41 54 45 5f 44 49 53 43 4f 4e 4e 45 43 54 45 44 | 148) id=2
183327.148 6 2 1 RecSoundStop begin trunc100ms=0, sCaller=Line_Hangup_Main
183327.148 6 2 1 q tel add cmd_RecordStop [0,0,0,0,0][||||]
183327.148 7 2 1 q tel run cmd_RecordStop
183327.148 6 2 1 GoOnHoook_IssueDropCall start (hCall_crn=28401da, yLineStateAppPov=Disconnect_Pending)
183327.148 6 2 1 WriteToLogFiles_CurrScriptOnly begin
183327.148 6 2 1 WriteToLogFiles_DoWrite begin : strLogFnameLessSuffix=C:\Program Files\VoiceGuide\Scripts\manager\all_custom_new
183327.148 6 2 1 WriteToLogFiles_DoWrite : log subdirectory does not exist: C:\Program Files\VoiceGuide\Scripts\manager\log
183327.148 6 2 1 WriteToLogFiles_DoWrite completed
183327.148 6 2 1 RvSaveToLogFiles_CurrAndStack iScriptCallStack_LastUsed_Idx=0
183327.148 6 2 1 t timer set 4 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall
183327.148 6 2 1 q tel add cmd_DropCall [0,0,0,0,0][||||]
183327.148 6 2 1 GoOnHoook_IssueDropCall end
183327.148 6 2 1 ls set Disconnected (scriptstate=LS_ENDINGCALL)
ktTel:
183238.648 3320 18 CtEventProcess idx=101 : evttype=134(134), crn=0, data=0904A9C8(08B69E60), len=28(28) q: 0/3
183238.648 3320 18 ev TDX_CST (CST Event Received)
183238.648 3320 18 TDX_CST DE_TONEON cst_data=1017
183238.648 3320 18 tone description retrieve hli=11130EC8, iToneUserID[2]=1017 sToneUserName[2]=[FAX]
183238.648 3320 16 r Dialogic TDX_CST 134 (1017 0 0 DE_TONEON FAX )
183327.148 3320 2 CtEventProcess idx=102 : evttype=2086(2086), crn=28401da, data=0904A9F8(0F281560), len=28(28) q: 0/3
183327.148 3320 2 ev GCEV_DISCONNECTED crn=28401da
183327.148 3320 2 gc_ResultValue: event 0x826 received on ldev: 2 - Normal completion
183327.148 3320 2 gc_ResultValue: GC_ISDN_LIB 0x826 received on ldev: 2 - Normal clearing
183327.148 3320 2 CTelProxy::Event_CallState GCEV_DISCONNECTED iLineCallState=16384, hCall=42205658 m_pktTelProxyClient=006E1400
183327.148 3320 2 r CallState GCEV_DISCONNECTED
183327.148 4896 2 fn RecordStop(iLineId=2, iActionID=0, sFileName=, iTruncTimeMs=0, iTruncBytes=0, sXMLOptions=)
183327.148 4896 2 TelDriver_RecStop lTruncMs=0, lTruncBytes=0
183327.148 4896 3 dx_stopch call in RecStopTruncate
183327.148 4896 3 dx_stopch 3 ok in RecStopTruncate
183327.179 4896 2 fn DropCall(sLineId=2, sXMLOptions=[], crn=0)
183327.179 4896 2 TelDriver_DropCall(sXMLOptions=[], crn_in=0)
183327.179 4896 2 clearing sDTMFsReceivedBeforeCallAnswer in TelDriver_DropCall
This event:
Indicates that a tone "DISCONNECT_USER_1" defined in ConfigLine.xml was detected.
You can stop this tone from being detected by deleting its definition from ConfigLine.xml or changing the frequencies & cadences so that it less likely to be falsely detected.
This event:
is the GCEV_DISCONNECTED event that indicates that an ISDN DISCONNECTED message arrived for that channel. ie. other leg of call has disconnected. (as described in previous responses in this thread)
So I was deleted DISCONNECT_USER_1, DISCONNECT_USER_2 and FAX frequency definitions to eliminate this kind of disconnecting cases.
I found few unexpected disconnected calls and each one has reason DISCONNECT_USER_1, DISCONNECT_USER_2 or FAX so I thing it was source of problems.
I'm using PRI ISDN so is any other parameter witch should I delete to be sure that only ISDN signals controlling call disconnecting?
Deleting DISCONNECT_USER_1 and DISCONNECT_USER_2 from ConfigLine.xml will remove those tone definitions.
There may be other "DISCONNECT" tone definitions in your ConfigLine.xml file. eg: TID_DISCONNECT
To disable it you need to change its settings to something unlikely to be detected. eg:
<Freq1>600</Freq1>
<Freq1Dev>20</Freq1Dev>
<Freq2>800</Freq2>
<Freq2Dev>20</Freq2Dev>
<On>200</On>
<OnDev>10</OnDev>
<Off>200</Off>
<OffDev>10</OffDev>
<Count>10</Count>
Please post your current Config.xml and the ktTel trace that captures system startup.
We can then better advise what changes to make.
one more case:
105454.858 6 10 4 rv replace end [on {timeout 2957} goto [play warning]
on {GCEV_TASKFAIL} goto [C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_temination_pro_15.vgp|]
on {GCEV_RESETLINEDEV} goto [C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_temination_pro_15.vgp|]
105454.858 6 10 4 path {2} not found
105515.202 18 10 4 ev CallState GCEV_DISCONNECTED, crn=28000cf, iEvent=2 ,16384,0,64,,,]. vgEngine v7.3.4413.40408 (2012-01-31 22:26:55.92)
105515.202 18 10 4 q scr add evCallState 2 GCEV_DISCONNECTED
It shows that caller pressed "2" button? How to ignore any input witch can disconnecting call?
105515.202 6 10 4 q scr run evCallState sCode=[GCEV_DISCONNECTED] iActionID=0, crn=28000cf[16384|0|64|0|0][|||||]
105515.202 6 10 4 LineEvCallState crn=28000cf event=2|GCEV_DISCONNECTED iCallState=16384 calldirection=0 gcCallState=64 [||]
105515.202 6 10 4 LineEvCallState eLineStateThisEvent=Disconnected, ScriptState=LS_PLAY_PLAYMSGFINISHED
105515.202 6 10 4 HangupCall, source=LINECALLSTATE_DISCONNECTED, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
105515.202 6 10 4 moduleTitle=[just wait]
105515.202 6 10 4 ScriptWorkingMode set Stopping, (called from HangupCall)
105515.202 6 10 4 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL)
105515.202 6 10 4 state Hanging up... [LINECALLSTATE_DISCONNECTED]
105515.202 6 10 4 rv add [Hangup Source]{LINECALLSTATE_DISCONNECTED}
105515.217 6 d added Hangup Source | LINECALLSTATE_DISCONNECTED | ( 48 61 6e 67 75 70 20 53 6f 75 72 63 65 | 4c 49 4e 45 43 41 4c 4c 53 54 41 54 45 5f 44 49 53 43 4f 4e 4e 45 43 54 45 44 | 122) id=10
105515.217 6 d added Hangup Source | LINECALLSTATE_DISCONNECTED | ( 48 61 6e 67 75 70 20 53 6f 75 72 63 65 | 4c 49 4e 45 43 41 4c 4c 53 54 41 54 45 5f 44 49 53 43 4f 4e 4e 45 43 54 45 44 | 180) id=10
105515.217 6 10 4 GoOnHoook_IssueDropCall start (hCall_crn=28000cf, yLineStateAppPov=Disconnect_Pending)
105515.217 6 10 4 WriteToLogFiles_CurrScriptOnly begin
105515.217 6 10 4 WriteToLogFiles_DoWrite begin : strLogFnameLessSuffix=C:\Program Files\VoiceGuide\Scripts\Maciej\prepaid_2011_10_14
105515.217 6 10 4 WriteToLogFiles_DoWrite : log subdirectory exists, strLogFnameLessSuffix=C:\Program Files\VoiceGuide\Scripts\Maciej\log\prepaid_2011_10_14
105515.217 6 10 4 WriteToLogFiles_DoWrite completed
105515.217 6 10 4 RvSaveToLogFiles_CurrAndStack iScriptCallStack_LastUsed_Idx=0
105515.217 6 10 4 t timer set 4 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall
105515.217 6 10 4 q tel add cmd_DropCall [0,0,0,0,0][||||]
105515.217 6 10 4 GoOnHoook_IssueDropCall end
105515.217 7 10 4 q tel run cmd_DropCall
105515.217 6 10 4 ls set Disconnected (scriptstate=LS_ENDINGCALL)
105515.217 6 10 4 yLineStateAppPov: Disconnected crn=28000cf,ev=2,GCEV_DISCONNECTED,0, sParam1=
105515.217 6 19 7 q scr add evScriptEvent 0 OTHER_LEG_Disconnected
105515.217 6 10 4 LineEvCallState LINECALLSTATE_DISCONNECTED begin
105515.217 6 10 4 ignore callstate LINECALLSTATE_DISCONNECTED event as current linestate is Disconnected
105515.217 6 19 7 q scr run evScriptEvent sCode=[OTHER_LEG_Disconnected] iActionID=0, crn=0[16384|0|64|0|0][|||||]
105515.217 6 19 7 scriptevent OTHER_LEG_Disconnected 16384|0|64 ||
105515.217 6 19 7 LsXfer_9_WaitEndCall_OutLeg : 0(), [OTHER_LEG_Disconnected], 16384,0,64,,,
105515.217 6 19 7 hanging up 2nd leg of call (other leg cause)
105515.217 6 19 7 HangupCall, source=xfer_9_leg2 remote, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
105515.217 6 19 7 ScriptWorkingMode set Stopping, (called from HangupCall)
105515.217 6 19 7 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL)
105515.217 6 19 7 state Hanging up... [xfer_9_leg2 remote]
attached files please For Your Eyes Only ...
ConfigLine.zip
ktTel.zip
button 2 was pressed at 105454.858
ISDN DISCONNECTED event arrived at 105515.202 (20 seconds later).
these two events are not related.
The attached ConfigLine file does not have TID_DISCONNECT entry.
To disable TID_DISCONNECT you need to change the Dialogic default setting for this tone to something unlikely to be detected.
This requires inclusion of TID_DISCONNECT entry in the ConfigLine.xml file.
Like an example below:
<Tone Name="Call Progress Tone TID_DISCONNECT">
<Notes>Default Setting</Notes>
<ID>TID_DISCONNECT</ID>
<Freq1>600</Freq1>
<Freq2>800</Freq2>
<On>200</On>
<OnDev>10</OnDev>
<Off>200</Off>
<OffDev>10</OffDev>
<Count>10</Count>
</Tone>
Can You write correct <Tone Name="Call Progress Tone TID_DISCONNECT"> into my config file?
Have You any list of Disconnect Events (CODES ) shown in log files?
I want to be sure that disconnections happens only in expected by callers reasons.
Please see attached file. This a suitable ConfigLine file for your ISDN based system.
The disconnect will be either due to tone present, or due to ISDN event.
Tone codes would be the ones that are listed in ConfigLine file, and the ISDN Disconnect event is reported as GCEV_DISCONNECTED.
ConfigLine.zip
