Say Numbers -- Sounds Distored
Hi -- I recently downloaded the evaluation version of Voice guide to test replacement of our version 5.2 installation. The new installation uses VoIP and HMP. I am using the same script that works perfectly in 5.2. When I test the script and I get to the module that says entered numbers back; the numbers sound distorted. I have attached the trace.0708_1358_vgEngine.zip
Ok So if I understand correctly... the .wav files that we recorded are in a different format(Ulaw/Alaw) from the ones that were installed when I installed voice guide and selected the format(Ulaw). so in order to correct this I should remove and reinstall voice guide and select the Alaw format? Or is there something else i need to do also?
Your sound files that you use in Say Number module(s) need to be recorded in ULaw.
No need to reinstall VoiceGuide.
