Call Tx
specs=see avatar
when #A calls #B and #B transfers via txmodule to #C....I can only see caller id from #B.
How do I pass on #A caller id to #c which is my cell phone.
I need to be able to see the caller id number of the original caller
not my office number which transfers the call.
please advise
thanks inadvance
You would need to speak to your phone company to see if they can do this. Its they that could do this, not VoiceGuide. Highly unlikely that they would give you this option though.
I was more thinking in line of some genuis in here
would be able to script collected caler id info
and then somehow convert it to voice format and apply it to a custom greeting
so it can anounce this info when the call is transfered to my cell phone
via monitored transfer.
then again I am not a programmer, just a system intergrator
btw: whats the licensing standard for scripted add ons tyo your product
please direct me to the appropriate information.
thanks
VoiceGuide can do this right now.
(I though you wanted for CallerID to be displayed on the #C phone before the call is answered.)
To play the CallerID in the announce message just create the list of what sound files to play, save it to $RV, and then use the $RV in the "Announce Message" field.
eg. if CallerID is 1234 then use a script to create a string like this:
callfrom.wav,1.wav,2.wav,3.wav,4.wav,press1toaccept.wav
then save it in $RV, say: $RV[CidAnnounce]
and then in the transfer module, in the "Announce Message" field just specify:
$RV[CidAnnounce]
You can also create your own transfer management by using the Play modules to do the hookflashed and play the DTMF tones and then use the Say Number modules to to handle the number playing.
Suggest you read:
http://www.voiceguide.com/vghelp/source/ht...ltvariables.htm
http://www.voiceguide.com/vghelp/source/ht...odsaynumber.htm
No licensing is required for those. If you want to sell a script that you have created then you are free to do so.
If you want to resell VoiceGuide licenses then please contact sales@voiceguide.com
thankks4followup
your above response is based on a static concept
meaning I would know the callers number in advance then create the wave file based on this number.
My interest is in a dynamic environment were I would not know the callers number inadvance
and the script would have to collect current caller id info, convert it to wave file on the fly
or
maybe the caller id value can be read using built in number prompts
am I reaching for the moon
please advise
did not know how to edit above post
I believe you answered my question via linls provided
I am having trouble with $RV module
would you be kind enough to provide a sample base on
"your above response is based on a static concept
or
maybe the caller id value can be read using built in number prompts"
the sample for the static id info is great
Please provide a samble for dynamic environment.
thanks inadvance
thanks for your response.
I looked at those and unable to make heads and tails out of it.
Would you be kind enough to provide a dynamic sample (when there is no previous record of the calling number)
of the callerid number being anounced when making a transfer to a cell phone.
thanks inadvance
Actually, have you even tried doing an announced transfer? The CallerID should be played by default anyway if you leave the "Announce Message" blank.
Please post VoiceGuide traces from your system which capture the entire call along with the announced transfer.
Trace files are created in VG's \log\ subdirectory.
thanks 4 the followup:
this solved the issue:
"Have a look at and go through the attached script. Attached File(s) AnnouncedCidTransfer.vgs ( 1.52K ) "
they say picture is worth a thousandth words! (-:
Please note that you should not need to use the supplied script. If CallerID is available then the Announced Transfer option will already speak the CallerID it by default.
hello,
"Please note that you should not need to use the supplied script.
If CallerID is available then the Announced Transfer option will already speak the CallerID it by default"
for the above quote I was only able to see the number from which the call was transfered from.
not from which it originated.
ie: inbound call (cid#1111111111) to office transfer (cid#2222222222) to cell phone which anounced call by (cid#2222222222)
without the script I am not able to hear cid#1111111111 on my cell phone.
Could you please post a copy of VoiceGuide's Trace Logs which captures the transfer, this will allow us to see what happened.
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=0
ktTts=0
