T1 Not Dialing
Using D/240JCT and v7 but cannot get the system to make a call. The system says 'Dialing' but it flashes real quick and disappears without making a call. Can someone please call and help. 1800-864-6210. Our config file is attached.
Config.zip
Instructions on setting up ISDN lines can be found here: http://www.voiceguide.com/vghelp/source/ht...igisdnsetup.htm
As per instructions you may need to test with ISDAIG first and do traces (using ISDIAG) on incoming calls to see if any custom non-standard fields are used by the Telco on this T1.
We do offer an installation service where we log into your system over the internet using www.logmein.com or VNC or similar. Please contact sales@voiceguide.com for details of this service if required.
