Error In Verify Entered Number Script
We are using Licensed VG 7. Here Below script i am trying to execute but giving error. Plz look at the code and Log file below.
For Ev = 1 To Len("$RV_ENTEREDNUMBER") - 2 Step 2
ESChr = Mid("$RV_ENTEREDNUMBER"), Ev + 1, 1)
K = K + ESChr
Next Ev
For Od = 1 To Len("$RV_ENTEREDNUMBER") Step 2
OSChr = Mid("$RV_ENTEREDNUMBER", Od, 1) * 2
If Len(OSChr) = 2 Then
OSChr = Val(Left(OSChr, 1)) + Val(Right(OSChr, 1))
End If
J = J + OSChr
Next Od
If (10 - Right((J + K), 1)) = Val(Right("$RV_ENTEREDNUMBER", 1)) Or (10 - Right((J + K), 1)) = 10 Then
sResult = "Success"
Else
sResult = "Fail"
End If
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
Emarat.zip
If this is ran as the Get Numbers' "Verify Entered Number" script then the returned values should be: "verify_passed" and "verify_failed" instead of "Success" and "Fail". Please see: http://www.voiceguide.com/vghelp/source/ht...odgetnumber.htm
Please also use Admin_TraceLogAdd (http://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm) throughout the script to see how the script progresses and at which stage the fault occurs. Admin_TraceLogAdd will place entries in the vgEngine log file.
