Using Voiceguide With Avtech's Pager System
Has anyone had any luck in using VoiceGuide basic download edition in conjunction with an environmental alarm system to alert a list of techs about the problem via standard phone connection?
If so, how did you do it and is it working to your satisifaction?
Is the Environmental alarm system which you are using able to run a program or a script when an event occurs? If it can then the program/script you would run should be designed to load an outbound call into VoiceGuide. Calls can be loaded using any of these approaches:
- Using VoiceGuide COM interface function Dialer_OutDialQueAdd.
- Saving list of numbers to be called in an 'Out Dial' file, which VoiceGuide reads in automatically.
- Adding dial entries directly to the OutDialQue database.
See: http://www.voiceguide.com/vghelp/source/ht...iallistinto.htm
You can use the Result Variables parameters to pass call-specific information (eg temperature (?)), or let callers query the environmental alarm system values if they are available through a database etc.
You should use a Dialogic card in any system that does outbound calls.
