Vbs Returns "verify_passed", But Fail Path Taken.
I have a simple VBS module that is running right of the start of my script. It does two simple queries to make sure the databases are online, and returns a "verify_passed" if they are.
When I test it, it takes the fail path. I've taken the VBS out of VG, to verify that it's working properly and it does.
Back in VG, if I turn on a msgbox to see the variable that's returning the verify code, it says "verify_passed", however the module that I've specified as the fail path starts to run.
Here is the VB I'm running (with security sensitive info removed). This is a version of the VB for testing outside of VG, hence the vg lines have been commented out.
VBS START
_____________________________________________
dim objDBConnection, objDBRecordset, vg, query, sResult
'set vg = CreateObject("VoiceGuide.CommandLink")
Const adOpenStatic = 3
Const adLockOptimistic = 3
Const adUseClient = 3
Set objDBConnection = CreateObject("ADODB.Connection")
Set objDBRecordset = CreateObject("ADODB.Recordset")
'connect to DB
objDBConnection.Open "DRIVER={MySQL ODBC 3.51 Driver};SERVER=SERVER;DATABASE=DB;USER=ME;PASSWORD=PWORD;"
objDBRecordset.CursorLocation = adUseClient
query = "SELECT users.user_id FROM users WHERE users.active='Y' AND users.title_type=6;"
objDBRecordset.Open query, objDBConnection, adOpenStatic, adLockOptimistic
if objDBRecordset.RecordCount > 0 then
sResult="verify_passed"
else
sResult="verify_failed"
end if
objDBRecordset.Close
query = "SELECT merch_timesheets.trx_id FROM merch_timesheets;"
if sResult="verify_passed" then
else
end if
else
end if
msgbox sResult
'vg.Run_ResultReturn $RV_LINEID, sResult
'set vg = Nothing
'set objDBConnection = Nothing
'set objDBRecordset = Nothing
' END CODE_____________________________________________
[Log]
VoiceGuide=10
Trace shows that after the call is answered a "Run VBscript" type module titled "DBpreCheck" is first ran:
151412.86 2 state [DBpreCheck] Running VB Script...
The "verify_passed" and "verify_failed" returnes are only meant to be used in a verification VBScript which is ran in a Get Number module.
In a normal "Run VBScript" module you should use "success" or "fail" return codes.
Please see: http://www.voiceguide.com/vghelp/source/html/modvbs.htm and http://www.voiceguide.com/vghelp/source/ht...odgetnumber.htm
