Tranfer A Call
Can you tell me how I can can give a command to transfer a call to an other extension?
I wrote a script and I must send a DTMF string to make the connection. I am using a Meridian 1 Option 11 PBX. I am trying &,extension but it doesn't work. I am using the D/160Sc-LS Dialogic 16 ports card.
I need help please.
Regards,
Gulano
Just use the Call Transfer module...
Have you tried it?
You can also send DTMF strings using the "Play" module. Just type the DTMF string in the "Sound file to play" text field and that DTMF string will be played.
Use an exclamation mark ! to indicate sending a hookflash.
Hello support team,
I tried the AutoAttendant.vgs script in the directory:
C:\Program Files\VoiceGuide\Scripts\more sample scripts\
AutoAttendant\AutoAttendant.vgs.
I did it also with your advice.
I configure the Sales module to transfer the call to extension 4543 but it doesn't work.
I choose at the Sales properties for Phone:4543 and for transfer I choose for PBX Blind Transfer.
When I installed the dialogic software I left every settings on default.
Question:
Must I change any settings on the card to make call transfer able?
Here is the logfile:
092927.88 6 linedevstate 2048 0 0
092927.88 6 callstate OFFERING 66390 0 4
092927.88 6 callinfo CALLEDID
092927.89 6 callinfo ORIGIN
092927.89 6 ring 0
092928.39 0 dial start any summary:|6:hc>0|
092933.90 6 ring 2
092933.90 6 rv clear
092933.90 6 Answer the call at 03/03/06 9:29:33 AM
092933.91 6 lineAnswer(66390) => 66339
092934.44 6 callstate CONNECTED 66390 1 0
092934.44 6 callstate CONNECTED 66390,1,0
092934.45 6 WorkingModeTAPI@Connected=
092934.45 6 WorkingModeScript@Connected=
092934.46 6 Inband detection not enabled
092934.46 6 StartLoadedVgs at 03/03/06 9:29:34 AM, script interpretor VgMulti v5.2.5003 0
092934.47 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\}
092934.47 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant}
092934.48 6 rv lg add [$RV_STARTTIME]{03/03/06 9:29:34 AM}
092934.48 6 rv lg add [$RV_DEVICEID]{6}
092934.49 6 rv lg add [$RV_CIDNAME]{}
092934.49 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
092934.50 6 rv lg add [$RV_CIDNUMBER]{}
092934.51 6 rv lg add [$RV_DNIS]{}
092934.51 6 rv lg add [DNIS]{}
092934.52 6 tapi Reply (LineEvReply) ok 66339 0
092934.52 6 callinfo MONITORMODES
092934.53 6 timer clear
092934.53 6 [Welcome] Number Input
092934.54 6 [Welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Test JAY-GUL\0303082052_6_.wav)
092934.55 6 play set playid=697230
092934.57 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Test JAY-GUL\0303082052_6_.wav]
092934.58 6 timer clear
092934.58 6 wa(21376,69723000)
092934.59 6 callinfo MONITORMODES
092942.43 6 dtmf 2 (66390,50,2)
092942.43 6 ScriptEventCode 50 iLineState=1300
092942.44 6 LsGetNbrsPlayWelcMsg 2
092942.49 6 PlaySoundStop err=0
092942.50 6 [Welcome] Number Input 2
092942.51 6 rv lg add [Welcome]{2}
092942.51 6 rv ns add [Welcome_PathTaken]{2}
092942.52 6 timer clear
092942.52 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
092942.92 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
092942.93 6 ScriptEventCode 9012 iLineState=1900
092942.93 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
092942.94 6 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
092942.94 6 [sales] Blind Transfer to 4543 (Generate)
092942.98 6 tapic lineGenerateDigits(66390 [!] 100) => ok
092943.63 6 generate LINEGENERATETERM_DONE
092943.64 6 timer set 1 EV_TAPI_GENERATE
092944.59 6 timer fired EV_TAPI_GENERATE
092944.59 6 ScriptEventCode 9602 iLineState=1900
092944.59 6 LsXferStart EV_TAPI_GENERATE
092944.61 6 timer set 1 EV_HOOKFLASHFINISHED
092945.61 6 timer fired EV_HOOKFLASHFINISHED
092945.62 6 ScriptEventCode 9200 iLineState=1905
092945.62 6 LsXferPlayVts EV_HOOKFLASHFINISHED
092945.63 6 tapic lineGenerateDigits(66390 [4543] 100) => ok
092946.34 6 generate LINEGENERATETERM_DONE
092946.35 6 timer set 1 EV_TAPI_GENERATE
092947.34 6 timer fired EV_TAPI_GENERATE
092947.35 6 ScriptEventCode 9602 iLineState=1905
092947.35 6 LsXferPlayVts EV_TAPI_GENERATE
092947.36 6 timer set 3 EV_TIMEOUT_HANGUP
092948.26 6 callstate DISCONNECTED 66390 0 0
092948.27 6 ScriptEventCode 9250 iLineState=1905
092948.27 6 LsXferPlayVts EV_REMOTEPARTY_DISCONNECT
092948.28 6 rv lg add [Hangup Time]{03/03/06 9:29:48 AM}
092948.29 6 Hanging up call...
092948.29 6 RecSoundStop ok
092948.30 6 PlaySoundStop err=0
092948.30 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
092948.31 6 fnHangupCall end
092948.34 6 linedevstate 2048 0 0
092948.35 6 callstate IDLE 66390 0 0
092948.36 6 WorkingMode@Idle=
092948.36 6 timer clear
092948.40 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092948.41 6 tapi Reply (LineEvReply) ok 66322 0
092949.32 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
092949.32 6 ScriptEventCode 9008 iLineState=900
092949.33 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
092949.33 6 ReinitTelephony due to IDLE
092949.34 6 tapic lineDeallocateCall(MainCall:66390) 0
092949.40 6 lineOpen(6)=>
092949.40 6 Waiting for a call...
092949.41 6 LineHandle=66287
092949.42 6 amchk set AMdet=False in Reinit@idle
092949.42 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092949.43 0 dial start any summary:|6:rdy=0|
092952.43 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092952.45 6 ScriptEventCode 9013 iLineState=900
092952.46 0 dial start any summary:|6:idx=0|
092956.92 6 linedevstate 2048 0 0
092956.92 6 callstate OFFERING 66270 0 4
092956.93 6 callinfo CALLEDID
092956.94 6 callinfo ORIGIN
092956.95 6 ring 0
092957.55 0 dial start any summary:|6:hc>0|
093002.94 6 ring 2
093002.94 6 rv clear
093002.95 6 Answer the call at 03/03/06 9:30:02 AM
093002.95 6 lineAnswer(66270) => 66219
093003.49 6 callstate CONNECTED 66270 1 0
093003.50 6 callstate CONNECTED 66270,1,0
093003.51 6 WorkingModeTAPI@Connected=
093003.51 6 WorkingModeScript@Connected=
093003.53 6 Inband detection not enabled
093003.53 6 StartLoadedVgs at 03/03/06 9:30:03 AM, script interpretor VgMulti v5.2.5003 0
093003.54 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\}
093003.54 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant}
093003.55 6 rv lg add [$RV_STARTTIME]{03/03/06 9:30:03 AM}
093003.56 6 rv lg add [$RV_DEVICEID]{6}
093003.56 6 rv lg add [$RV_CIDNAME]{}
093003.57 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
093003.58 6 rv lg add [$RV_CIDNUMBER]{}
093003.58 6 rv lg add [$RV_DNIS]{}
093003.59 6 rv lg add [DNIS]{}
093003.60 6 tapi Reply (LineEvReply) ok 66219 0
093003.60 0 sys cleanup Start
093003.61 0 sys cleanup End
093003.62 6 timer clear
093003.62 6 [Welcome] Number Input
093003.63 6 [Welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Test JAY-GUL\0303082052_6_.wav)
093003.64 6 play set playid=726322
093003.66 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Test JAY-GUL\0303082052_6_.wav]
093003.66 6 timer clear
093003.67 6 wa(21376,72632200)
093003.68 6 callinfo MONITORMODES
093019.75 6 callstate DISCONNECTED 66270 0 0
093019.77 6 ScriptEventCode 9250 iLineState=1300
093019.77 6 LsGetNbrsPlayWelcMsg EV_REMOTEPARTY_DISCONNECT
093019.77 6 rv lg add [Hangup Time]{03/03/06 9:30:19 AM}
093019.79 6 Hanging up call...
093019.80 6 RecSoundStop ok
093019.86 6 PlaySoundStop err=0
093019.86 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
093019.86 6 fnHangupCall end
093019.91 6 linedevstate 2048 0 0
093019.91 6 callstate IDLE 66270 0 0
093019.91 6 WorkingMode@Idle=
093019.93 6 timer clear
093019.93 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
093019.93 6 tapi Reply (LineEvReply) ok 66236 0
093020.88 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
093020.88 6 ScriptEventCode 9008 iLineState=900
093020.89 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
093020.89 6 ReinitTelephony due to IDLE
093020.89 6 tapic lineDeallocateCall(MainCall:66270) 0
093020.96 6 lineOpen(6)=>
093020.96 6 Waiting for a call...
093020.96 6 LineHandle=66185
093020.96 6 amchk set AMdet=False in Reinit@idle
093020.98 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
093021.65 0 dial start any summary:|6:rdy=0|
093023.99 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
093023.99 6 ScriptEventCode 9013 iLineState=900
093024.67 0 dial start any summary:|6:idx=0|
Hello Support Team,
I followed the instructions at: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm
I configured every thing again and now when I press a key (2) after hearing the intro at the beginning to transfer a call, it rings 1 time and then hang up.
Can you tell me what is now wrong?
here is the logfile:
123738.41 5 devstate NUMCALLS 0 0
123738.42 5 tapi callstate start
123738.43 5 tapi callstate OFFERING 65723 0 4
123738.45 5 rv clear
123738.45 5 Answer the call at 3/6/2006 12:37:38 PM
123738.50 5 lineAnswer(65723) => 65706
123738.52 5 callinfo CALLEDID
123738.52 5 callinfo ORIGIN
123738.53 5 ring 0
123738.88 0 dial start any summary:|5:hc>0|
123739.08 5 tapi callstate start
123739.09 5 tapi callstate CONNECTED 65723 1 0
123739.10 5 callstate CONNECTED 65723,1,0
123739.11 5 WorkingModeTAPI@Connected=
123739.12 5 WorkingModeScript@Connected=
123739.25 5 Inband detection not enabled
123739.29 5 StartLoadedVgs at 3/6/2006 12:37:39 PM, script interpretor VgMulti v5.2.5012 0
123739.30 5 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\}
123739.32 5 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant}
123739.34 5 rv lg add [$RV_STARTTIME]{3/6/2006 12:37:39 PM}
123739.36 5 rv lg add [$RV_DEVICEID]{5}
123739.39 5 rv lg add [$RV_CIDNAME]{}
123739.41 5 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
123739.44 5 rv lg add [$RV_CIDNUMBER]{}
123739.46 5 rv lg add [$RV_DNIS]{}
123739.48 5 rv lg add [DNIS]{}
123739.54 5 tapi Reply (LineEvReply) ok 65706 0
123739.56 5 callinfo MONITORMODES
123739.60 5 timer clear
123739.62 5 state [Welcome] Number Input
123739.65 5 state [Welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav)
123739.68 5 play set playid=252322
123740.00 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
123740.03 5 timer clear
123740.07 5 callinfo MONITORMODES
123752.09 5 play end current play (playid=252322)
123752.11 5 ScriptEventCode 8001 iLineState=1300
123752.16 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
123752.18 5 eng set timer EV_TIMEOUT_REPLAYMSG time=2
123752.21 5 timer set 2 EV_TIMEOUT_REPLAYMSG
123752.88 5 dtmf 2 (65723,50,2)
123752.90 5 ScriptEventCode 50 iLineState=1301
123752.92 5 LsGetNbrsRxDigits 2
123752.94 5 state [Welcome] Number Input 2
123752.97 5 rv lg add [Welcome]{2}
123752.99 5 rv ns add [Welcome_PathTaken]{2}
123753.03 5 timer clear
123753.05 5 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
123753.41 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
123753.43 5 ScriptEventCode 9012 iLineState=1900
123753.45 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
123753.47 5 timer set 3 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
123753.50 5 state [sales] Blind Transfer to 4543 (Generate)
123753.71 5 tapic lineGenerateDigits(65723 [!] 100) => ok
123758.89 5 generate LINEGENERATETERM_DONE
123758.91 5 timer set 1 EV_TAPI_GENERATE
123759.88 5 timer fired EV_TAPI_GENERATE
123759.90 5 ScriptEventCode 9602 iLineState=1900
123759.92 5 LsXferStart EV_TAPI_GENERATE
123759.94 5 timer set 1 EV_HOOKFLASHFINISHED
123800.97 5 timer fired EV_HOOKFLASHFINISHED
123800.99 5 ScriptEventCode 9200 iLineState=1905
123801.01 5 LsXferPlayVts EV_HOOKFLASHFINISHED
123801.10 5 tapic lineGenerateDigits(65723 [4543] 100) => ok
123801.90 5 generate LINEGENERATETERM_DONE
123801.93 5 timer set 1 EV_TAPI_GENERATE
123802.84 5 timer fired EV_TAPI_GENERATE
123802.86 5 ScriptEventCode 9602 iLineState=1905
123802.89 5 LsXferPlayVts EV_TAPI_GENERATE
123802.91 5 timer set 3 EV_TIMEOUT_HANGUP
123805.94 5 timer fired EV_TIMEOUT_HANGUP
123805.96 5 ScriptEventCode 9001 iLineState=1905
123805.99 5 LsXferPlayVts EV_TIMEOUT_HANGUP
123806.01 5 rv lg add [Hangup Time]{3/6/2006 12:38:06 PM}
123806.03 5 state Hanging up call...
123806.06 5 RecSoundStop ok
123806.08 5 PlaySoundStop err=0
123806.10 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
123806.15 5 fnHangupCall end
123806.21 5 devstate NUMCALLS 0 0
123806.23 5 tapi callstate start
123806.25 5 tapi callstate IDLE 65723 0 0
123806.27 5 WorkingMode@Idle=
123806.30 5 timer clear
123806.38 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
123806.40 5 tapi Reply (LineEvReply) ok 65655 0
123807.33 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
123807.35 5 ScriptEventCode 9008 iLineState=900
123807.37 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123807.39 5 ReinitTelephony due to IDLE
123807.44 5 tapic lineDeallocateCall(MainCall:65723) 0
123808.42 5 lineOpen(5)=>
123808.44 5 state Waiting for a call...
123808.46 5 LineHandle=65638
123808.48 5 amchk set AMdet=False in Reinit@idle
123808.52 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
123808.54 0 dial start any summary:|5:rdy=0|
123811.54 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
123811.56 5 ScriptEventCode 9013 iLineState=900
123811.66 0 dial start any summary:|5:idx=0|
123815.61 0 sys cleanup Start
123815.63 0 sys cleanup End
Thank you.
I see that you are using a blind transfer.
Is the caller put on hold when the hookflash is issued, or is the call hung up at the time when the card issues a hookflash?
btw. You really should be using VoiceGuide for Dialogic...
Sometimes you can hear that the call is transfered to the target phone.
It is ringing and when you pickup the phone you hear nothing and after a view seconds the call is ending.
Sometimes the caller put on hold when the hookflash is issued.
Sometimes you here a hangup and then it is dialing again.
I don't know what to do.
What do you mean with: You really should be using VoiceGuide for Dialogic... ?
I downloaded the software at:
http://www.voiceguide.com/vgDownload.htm
Which version is VoiceGuide for Dialogic... ?
Regards
Hello Support Team,
I tested the lines if they support call transfer by dialing with a telephone.
I noticed that two of the lines doesn't support call transfer and so I put two other lines which can. Now all the lines support call transfer.
There was an other problem.That was the hookflash time. I change the hookflash length to 89 and now I can transfer calls inside.
When I want to dial outside, I must change the hookflash length to 100 (example from a number inside to a mobile phone outside)
Now I want to connect two outside line to the patch panel, because I want to monitor an outside process and if there is a problem it must be able to dail from outside ( POTS to Mobile, POTS to POTS)
1)
I tried to put the appropriate hookflash lenght but I can't find it up till now.
It is realy frustrated to change the hookflash lenght every time.
Is there a way to put one hookflash lenght to dial from POTS to Mobile and from POTS to Pots?
2)
When I am dialing from a pbx (inside) to a mobile (outside) the mobile phone is ringing good after 3 miss calls. What is the problem that it can't ring good at the first call?
3)
After I picked up the mobile, I am hearing the middle of a message.
How can I configure the system or the software to play the message after I said hello ?
4)
I downloaded VoiceGuide for Dialogic. Should I overwrite the old files? How does it work?
Regards,
Gulano
The switch/pbx will only use one hookflash length. It does not care if the transfer is made internally or externally.
Have you tried using "Monitored Transfer".
Instructions are in the readme.txt file.
