Premium Rate Setup Advice
The card I want should have 1 or more RJ45 sockets (normal phone plugs).
It should be able to fit onto a standard modern motherboard (h/w) and
integrate with Windows XP TAPI drivers (s/w).
I think that made sense (!)
The solution is as follows:
RJ45 presentation in house links to PC Dialogic Board. PC acts as
answer machine with IVR capable of DTMF (digit recognition) and
crucially, digit capture
Example:
Speech 'Welcome, press any key to go to next stage'
Action press any key
Speech 'Please enter your full telephone number'
Action enter tell number which is stored on PC
Speech 'Thank you'
Action Call ends
Question: Will this software complete all these requirements and what hardware recomendations do you sugest?
Thanks,
Will
Can VoiceGuide do a data dip?
For example:
'Please enter the 6 digit PIN of the product'
DTMF enter 123456
'Thank you, we are looking up your product'
Check database entry 123456 and return associated speech
'You have selected Product X'
Is this possible?
OK, we should use Dialogic. What about the base system requirements?
We will run XP but what hardware spec?
Many thanks,
Will
