Limit For Record Time
Hi Every,
Im testing voicegide ivr program and i have a some quetions.
1. i made call recording script then i want to give record time limit for recording ex. 2 minutes. how can i give
2. in call recording system i give some digits input for stop recording ex. "Please press * button for stop your recording" when users press * button after their record finish record system record with * button tone
how can fix this problems
info_guncer.com
I want to give record time limit for recording ex. 2 minutes.
The Timeout path is used to specify the maximum length of recording.
Please see: http://www.voiceguide.com/vghelp/html/modRecord.htm :
Can you please tell us which version of VoiceGuide are you using and if you are using a Voice modem or a Dialogic card?
Also, could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
