Message Lamps
I have the evaluation package so message lamps should work, I have set all the lines so they can be used to make calls but nothing ever happens, I would imagine that you should be able to see some activity in the voiceguide screen or the trace.
Is there something that I am missing, I have entered the string required to turn on/off the lamps and I have left the field blank that indicates the lines to use so it should use any of the lines.
Will it use a line that is "waiting for a call"?
Regards
Stuart
Its ok I worked out the issue, because I left the field "Which lines to use to make calls to turn lamp ON/OFF" blank it does not try to make a call at all, once I enter the Tapi device numbers on the lines it is fine :-
122721.82 0 Tapi device 9 is: Brooktrout TAPI Express port 3
122721.82 0 Tapi device 8 is: Brooktrout TAPI Express port 2
122721.82 0 Tapi device 7 is: Brooktrout TAPI Express port 1
122721.84 0 Tapi device 6 is: Brooktrout TAPI Express port 0
122721.84 0 Tapi device 5 is: H323 Line
122721.84 0 Tapi device 4 is: IPCONF LINE
122721.84 0 Tapi device 3 is: LPT1T
122721.85 0 Tapi device 2 is: WAN Miniport (L2TP)
122721.85 0 Tapi device 1 is: RAS VPN Line 0
122721.85 0 Tapi device 0 is: AOpen FM56-SVV Soft PCI Modem
In the help file it is says "If the line selection text box is left blank then any of the currently available lines will be used.". Which to me means that of the lines used by VG would be used?
Is what I am saying correct. See attached file.
Regards
Stuart
Lamps.txt
because I left the field "Which lines to use to make calls to turn lamp ON/OFF" blank it does not try to make a call at all, once I enter the Tapi device numbers on the lines it is fine.
sounds like you have not updated the v5.2.1 install with the patch/bugfix which is available from http://www.voiceguide.com/vgDownload.htm
"any of the currently available lines will be used" means "lines controlled by VoiceGuide". You will need to install the patch/bugfix first.
