Have Full Version, but would like to try Dialer...
We have the full version, but would like to demo the dialer how can we do this ?
thanks
To unregister a registered version of VG please rename (or delete) the file userinfo.ini in VoiceGuide’s directory to something else and restart VG.
Then to go back to using a registered version just name that file userinfo.ini again (or just enter the registration code again)
I got this working, but for some reason it will not dial out still, It is something wrong with the element in the script attached ? I also found a csv file in the folder but it is still yet to callthe number ?
callback.zip
This is what I get in the log, but the scipt does not appear to make the outbound call ?
038.14 5 wb(92082800)
150038.22 5 Play End line[5] (id=920828)
150038.22 5 ScriptEventCode 8001 iLineState=1200
150038.22 5 LsRecPlayBeep EV_PLAY_FINISHED
150038.23 5 rv add [Record 2]{C:\Program Files\VoiceGuide\Scripts\vgscript\test.wav}
150038.28 5 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\vgscript\test.wav] ok
150038.28 5 RecFile[C:\Program Files\VoiceGuide\Scripts\vgscript\test.wav]
150038.30 5 TimeoutSet 600 EV_TIMEOUT_RECMAXTIME
150042.78 5 dtmf # (65831,35,2)
150042.78 5 ScriptEventCode 35 iLineState=1201
150042.78 5 LsRecRecording #
150042.84 5 RecSoundStopTruncBytes ok
150042.84 5 rec length RV: Record 2_RecLen100ms = 44
150042.86 5 rv add [Record 2_RecLen100ms]{44}
150042.86 5 rv add [Record 2_EndRecCause]{#}
150042.88 5 ScriptEventCode 8003 iLineState=5900
150042.88 5 TimeoutClear
150042.89 5 [Phone Message 3] Send Voice Message
150042.89 0 DialListDB_AddCall '0412537369', 0, 1, 2359, MoTuWeThFrSaSu, , 1, test.wav, , , [QueuedFrom]{C:\Program Files\VoiceGuide\Scripts\vgscript\testcallback_delete.vgs}, 60, 2, 5, ESCALATION:
150042.91 5 TimeoutClear
150042.92 5 rv add [Hangup Time]{6/04/2004 3:00:42 PM}
150042.92 5 Hanging up call... [Hangup Module]
150042.94 5 RecSoundStop ok
150042.95 5 PlaySoundStop err=0
150042.97 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
150043.00 5 fnHangupCall end
150043.03 5 linedevstate 2048 0 0
150043.05 5 callstate IDLE 65831 0 0
150043.08 5 WorkingMode@Idle=
150043.09 5 TimeoutClear
150043.11 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
150043.14 5 tapi Reply (LineEvReply) ok 66366 0
150044.14 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
150044.16 5 ScriptEventCode 9008 iLineState=900
150044.17 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
150044.19 5 ReinitTelephony due to IDLE
150044.20 5 tapic lineDeallocateCall(MainCall:65831) 0
150044.34 5 lineOpen(5)=>
150044.38 5 Waiting for a call...
150044.39 5 LineHandle=65785
150044.41 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
150047.70 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
150047.72 5 ScriptEventCode 9013 iLineState=900
thanks for all your help, one last thing.
the script is attached
just but wav is not playing back and we are getting this the logs
164533.97 5 linedevstate 2048 0 0
164533.97 5 callstate IDLE 65547 0 0
164533.97 5 WorkingMode@Idle=
164533.97 5 TimeoutClear
164533.97 5 LineState(iLineId).iVgsIdx = 0
164533.97 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
164533.98 5 tapi Reply (LineEvReply) ok 65685 0
164535.03 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
164535.03 5 ScriptEventCode 9008 iLineState=900
164535.03 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
164535.03 5 ReinitTelephony due to IDLE
164535.03 5 tapic lineDeallocateCall(MainCall:65547) 0
164535.13 5 lineOpen(5)=>
164535.13 5 Waiting for a call...
164535.13 5 LineHandle=65959
164535.13 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
164538.41 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
164538.41 5 ScriptEventCode 9013 iLineState=900
164736.97 0 sys cleanup Start
164736.97 0 sys cleanup End
164800.22 5 dial [8,0412537369,404061648,1,2359,MoTuWeThFrSaSu,,,,1,test.wav,NONE,test.wav,[Queue
From]{C:\Program Files\VoiceGuide\Scripts\vgscript\testcallback_delete.vgs},60,1,5,,none]
164800.22 0 dial callque update id=8 next call time 0404061653
164800.23 0 dial callque DB update returned
164800.23 5 dial found entry: tel[0412537369] ann[test.wav] vgs[NONE] am[test.wav]
164800.23 5 Dialing: 0412537369
164800.23 5 MakeCall => 66179
164800.23 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
164800.25 5 TapiCbTrigSet 66179 7002
164800.88 5 tapi Reply (LineEvReply) ok 66179 0
164800.88 5 TapiCbTrigClear
164800.88 5 linedevstate 2048 0 0
164800.89 5 callstate DIALTONE 65840 0 0
164800.89 5 callstate DIALING 65840 0 0
164800.89 5 callstate PROCEEDING 65840 0 0
164800.89 5 callinfo CALLEDID
164800.89 5 callinfo REASON
164800.89 5 Lev_CallerID [0000,]
164800.89 5 callinfo ORIGIN
164824.91 5 callstate CONNECTED 65840,1,0
164824.91 5 WorkingModeTAPI@Connected=
164824.91 5 WorkingModeScript@Connected=
164824.92 5 rv add [QueuedFrom]{C:\Program Files\VoiceGuide\Scripts\vgscript\testcallback_delete.vgs}
164824.92 5 rv add [OutDial_RetriesLeft]{1}
164824.92 5 rv add [$RV_STARTTIME]{6/04/2004 4:48:24 PM}
164824.94 5 rv add [$RV_DEVICEID]{5}
164824.94 5 rv add [$RV_CIDNAME]{}
164824.95 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
164824.95 5 rv add [$RV_CALLEDNUMBER]{0412537369}
164824.97 0 dial callque delete id=8
164824.98 5 AddRVns [OutDial_Result]{Contacted_Human}
164824.98 5 Live person answered, starting NONE
164824.98 2 tr NewVgsVgm_Goto NONE,,,,,0
164824.98 5 rv add [scriptEnd_Time]{6/04/2004 4:48:24 PM}
164825.00 5 rv add [scriptEnd_Goto_Script]{NONE}
164825.00 5 rv add [scriptEnd_Goto_Module]{}
164825.00 5 rv add [scriptStart_Time]{6/04/2004 4:48:24 PM}
164825.00 5 rv add [scriptStart_CalledFrom_Module]{Hangup the Call 1}
164825.00 5 NewVgsVgm_Goto=>Error: NewVgsVgm_Goto_Setup failed
164825.02 0 dial callque update id=8 next call time 0404061653
164825.02 0 dial callque DB update returned
164825.02 5 TimeoutSet 1 EV_TIMEOUT_HANGUP
164826.77 5 Timer fired EV_TIMEOUT_HANGUP
164826.78 5 ScriptEventCode 9001 iLineState=5200
164826.81 5 LsWaitAfterDialingOut EV_TIMEOUT_HANGUP
164826.83 5 rv add [Hangup Time]{6/04/2004 4:48:26 PM}
testcallback_delete.zip
Is the path to the script correct? That is the usual cause of such problem...
If there is a file at C:\Program Files\VoiceGuide\Scripts\vgscript\testcallback_delete.vgs then the attached .exe has some more trace logging around the area where the error mesage is showing - please update your v5.2.1 install with this file and try making the call again, then post the trace.
VgMulti_5.2.1024.zip
