Saving logs in database
After getting incoming call all logs will be saved in folder but i want save that logs in database also please let me know how can i do this.
I want to save logs in database  for outgoing and incoming
Do you want to save the entire CallEvents or vgEngine etc. logs in database? or some other logs?
Call event log like once calls ended i need to save complete information regarding the call in database.
The CallEvents log does not contain complete information about the call. It for example does not contain all the Result Variables created during the call etc.
Many users just save the selected information to database using a Database Query module ran from the 'After Hangup' script.
'After Hangup' script: https://www.voiceguide.com/vghelp/source/html/call_finish.htm
Database Query module: https://www.voiceguide.com/vghelp/source/html/moddbquery.htm
What are you trying to achieve by loading call events data into a database?
Would CDR records be enough?
CDRs are already saved into VoiceGuide's default backend database. See: https://www.voiceguide.com/vghelp/source/html/log_cdrs.htm
As far as a CallEvents log is concerned, it is in JSON format. You could write some external app that reads that file and loads information that is important to you from it at end of day into your database table.
Sample CallEvents entry below:
{ "call": {
  "crn": "8000001",
  "port": "1",
  "direction": "in",
  "time_start": "2019-01-07 19:37:38",
  "events": "
    193738.112|callstate|GCEV_OFFERED|10.1.1.76||10.1.1.59|[SIP_HDR_Request_URI]{sip:10.1.1.59}[SIP_HDR_Contact_URI]{sip:10.1.1.76:59761;ob}[SIP_HDR_CALLID]{3253bc02179c4d26bf7992643564511a}[SIP_HDR_FROM]{<sip:10.1.1.76>;tag=a58464dac8d94d918f1ea426c3655a02}[SIP_HDR_TO]{<sip:10.1.1.59>}[SIP_Header_Via]{SIP/2.0/UDP 10.1.1.76}[SIP_Header_From]{<sip}[SIP_Header_To]{<sip}[SIP_Header_Contact]{<sip}[SIP_Header_Call-ID]{3253bc02179c4d26bf7992643564511a}[SIP_Header_User-Agent]{MicroSIP/3.16.7}||0|2|8|0
    193738.119|command|cmd_AnswerCall|||||0|0|0|0
    193738.127|event|GCEV_OFFERED|10.1.1.76||10.1.1.59|[SIP_HDR_Request_URI]{sip:10.1.1.59}[SIP_HDR_Contact_URI]{sip:10.1.1.76:59761;ob}[SIP_HDR_CALLID]{3253bc02179c4d26bf7992643564511a}[SIP_HDR_FROM]{<sip:10.1.1.76>;tag=a58464dac8d94d918f1ea426c3655a02}[SIP_HDR_TO]{<sip:10.1.1.59>}[SIP_Header_Via]{SIP/2.0/UDP 10.1.1.76}[SIP_Header_From]{<sip}[SIP_Header_To]{<sip}[SIP_Header_Contact]{<sip}[SIP_Header_Call-ID]{3253bc02179c4d26bf7992643564511a}[SIP_Header_User-Agent]{MicroSIP/3.16.7}||2|0|8|0
    193738.188|event|GCEV_ANSWERED|||||2050|0|0|0
    193738.188|callstate|GCEV_ANSWERED|||||0|256|4|0
    193738.189|state|<offered> : cid=10.1.1.76 , dnis=10.1.1.59 connected|||||0|0|0|0
    193738.222|state|[Get Client ID] Number Input|||||0|0|0|0
    193738.238|state|[Get Client ID] Playing wav (PayGetId.wav)|||||0|0|0|0
    193752.703|callstate|GCEV_DISCONNECTED|||||0|16384|64|0
    193752.706|event|GCEV_DISCONNECTED|||||16384|0|64|0
    193752.741|event||LineEvCallState_DISCONNECTED||||0|0|0|0
    193752.741|command|cmd_DropCall|||||0|0|0|0
    193752.757|callstate|GCEV_DROPCALL|||||0|1|32|0
    193752.772|event|GCEV_DROPCALL|||||1|0|32|0
    193752.791|callstate|GCEV_RELEASECALL|GCST_NULL||||2137|0|0|0
  "length": "14.679"
