Recording Two Channels Same Time
We need to record separated channels to two files.
We try to use script below:
vg.Admin_TraceLogAdd $RV[Conf_LineId_1], 0, "rec_2lines $RV[session_id] call"
'strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "")
vg.Record_Start $RV[Conf_LineId_1], "channel_L.wav", 0
vg.Record_Start $RV[Conf_LineId_2], "channel_R.wav", 0
'vg.Admin_TraceLogAdd $RV[Conf_LineId_1], 0, "rec_2lines $RV[session_id] returned"
vg.Run_ResultReturn $RV[Conf_LineId_1], "success"
set vg = Nothing
two test calls shows:
channel_L.wav is long 2,988 sec and no sound recorded (silence)
channel_R.wav has full record of Agent side conversation duration (32 sec).
Please post the ktTel trace file from 5th December for this system.We can then see what is happening on this system and comment.
The recording on line 1 stopped due to silence being detected on that line:
819 135650.138 5076 3 ev TDX_RECORD (Record Completed)
820 135650.140 5076 2 termmask=TM_MAXSIL (hli->linedev=2)
821 135650.140 5076 2 Event_Silence begin
822 135650.140 5076 2 r Silence
Is it possible that there was silence on that line after the recording commenced?
You can try disabling silence detection in VG.INI, in section [PlayRecordConfig] set entry SilenceDetectLevel to 0, like this:
Silence detection level setting (or disabling) can also be done from within the script. Please see: http://www.voiceguide.com/vghelp/source/html/modrecord.htm
