D/4 Pci Vg5.1.7 Set-up
HI --
We are upgrading from VG 4.9.0 on a windows-98, voice modem set-up to VG 5.1.7 D/4 pci set-up under Windows-2k Pro, using a single analog voice line. Windows-2k was a CLEAN installation on a new hard drive. I had previously installed VG-4.9.0 but had problems getting it to work with the Dialogic card, so uninstalled it and then downloaded and installed VG-5.1.7 trial.
When I call into the system the Talker-32 application works great, answering the phone and playing recorded messages through the phone. Unfortunately, I can't get VG to play messages. VG answers the phone stopping the ringing, but does not register the incoming call and does not play the greeting.
I have installed the u-Law wave files, and have tested my own recorded files u-Law files using Talker-32. They work there, but not in VG. I have uninstalled and reinstalled VG-5.1.7 and get the same result.
I checked the VG help files, which did a very good job of helping with the troublesome Dialogic installation and TAPI driver & wave set-up, but a VG TROUBLESHOOTING section did not jump out at me.
Since I can't hear the files locally at the system now that the Dialogic wave drivers are installed, how should I record files, test and monitor the system? Must everything be done by calling into the system, or do I need to switch back and forth between the sound card and the Dialogic board?
Also, what are the troubleshooting/testing procedures I should use to help track down this problem?
Thanks.
You do not need to use u-Law files on D/4PCI. The files which ship with VG are OK.
Hi --
No Event Trace Log is present. Because no logs were generated, I completely uninstalled the VG5.1.7 package, restarted the system and completely re-installed it. Now VG works using the sample scripts but it still won't work with my pre-recorded wave files which are u-Law and VG 4.9.0 script. The .wav files DO work with the Talker-32, and were recorded on another windows system using the sound recorder application set to u-Law properties. Is re-using the script from 4.9.0 causing the problem?
It looks like I should be using pre-recorded TTS files using the Microsoft TTS. Do you have a link to the components that are required? Isn't the core agent technology already included in Windows-2k?
Thanks--
Hi --
The original problem (could not play sound files) has been resolved. After redoing the script that was used under VG-4.9.0 the sound files now play. I don't know if this is an incompatibility between versions, or if my script file was corrupted.
FYI, I found a $25 program from Alive Media {
http://www.alivemedia.net/ } that will convert text files to '.wav'. The Output is PCM 11025Hz, 16bit, Mono, which then needs to be run through the ms-sound recorder and converted to PCM 11025Hz, 8bit, Mono. The Alive Text to Speech program can do a batch convert, but the conversion must be done one file at a time with sound recorder.
Thanks, for your help.
