How To Monitoring Few Servers
It should be possible.
You would need to use multiple Line Status Monitor windows and just specify a different IP address in each Line Status Monitor app.
I can't connect writing in WCF Connection Parameters server address.
Only changing data in vg.ini we reach server line status monitor active.
It's working when I start first status monitor and then I change parameters in vg.ini and start second time status monitor.
In this case I see two monitor windows but isn't right solution.
If the Line Status Monitor app is started on same system where VoiceGuide is running then it will be default connect to the local VoiceGuide instance.
This is what is specified in VG.INI.
If you do not want for system to connect automatically then the settings in VG.INI's [statusMonitor] PortStatus_Wcf entry can be deleted, and you can then manually specify the connection string to use when the Line Status Monitor app is started.
A Line Status Monitor is designed to monitor a single VoiceGuide server. Multiple Line Status Monitors are needed to monitor multiple VoiceGuide servers.
Thanks.
after deleting PortStatus_Wcf entry I can to declare VG server IP address for several servers.
