Errors After Registration
Trace shows that you are trying to use VoiceGuide's COM interface:
132921.45   4 cl    Run_ResultReturn [[Run VB Script 12]{161}]
132921.45   4 ERROR: COM interface not supported in this version.
VoiceGuide's COM interface is only supported in the Enterprise version of VoiceGuide (please see: http://www.voiceguide.com/vgFeatures.htm )
You will need to use the Enterprise license on your system in order to use the COM interface.
Can I use the VB Script and just not use the filesystem object. Is that causing the error?
So instead of looking up in the file, can I just have a series of ifs
if $RV[get numbers 3] = "116 then idout= "101"
then return
vg.Run_ResultReturn $RV_LINEID, "[Run VB Script 12]{" & idout & "}"
You can use the filesystem object.
It is VoiceGuide's COM interface that is only supported in the Enterprise version of VoiceGuide
Your script is calling VoiceGuide's Run_ResultReturn COM function.
