Calling Vbscript
I am trying to call a VBscript and pass in the Voice Mail Box Id captured and return the voice mail Extension by parsing the
voicemail box xml file. I don't know how to pass in and return the extension. Here is the code but it errors out on the $RV variable on line 22
We are using a D/41H and Version 6.xxx of the voiceguide.
[Run VB Script 12]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsFileToRun=
VbsWait=1
VbScript=
set vg=CreateObject("VoiceGuide.CommandLink")
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile("C:\Program Files\VoiceGuide\Data\VmBoxList.xml", 1)
dim stuff
stuff = ""
i = 0
Do Until objFile.AtEndOfStream
stuff = stuff & objFile.ReadLine
loop
objFile.Close
'Then you can iterate it like this
' look up and then
x = "Id=" & chr(34) & $RV[get numbers 8]
y = instr(stuff,x)
if y <> 0 then
z = instr(y,stuff,"/Ext")
if z <> 0 then
idout = mid(stuff,z-4,3)
end if
end if
vg.Run_ResultReturn $RV_LINEID, "[Run VB Script 12]{" & idout & "}"
set vg=Nothing
VbsHoldPlay=
on {success} goto [Play 2]
on {fail} goto [Play 5]
on {success} goto [say Numbers 6]
Position=270,208
Try changing:
to:
x = "Id=" & chr(34) & "$RV[get numbers 8]"
the $RV[get numbers 8] would get replaced by its value exactly. You need to put the string quotes around that $RV if the string quotes are required to make expression correctly formatted.
If you are still going to encounter problems then please post the script that you are using along with the vgEngine trace (.ZIPed)
