Blaster Di5655
Hello
I hace a modem blaster DI5655 but it is not answering..
I attach the Log for its error.
28150 0 tapie callstate OFFERING 65673 0 4
28150 0 tapie ring 1
37143 0 tapie ring 2
37143 0 Answer the call
37143 0 lineAnswer(65673) => 65758
37143 0 tapie callstate ACCEPTED 65673 0 0
38305 0 tapi Reply 65758 LINEERR_OPERATIONFAILED [80000048]
38305 0 tapie callstate DISCONNECTED 65673,16384,0
38305 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
38305 0 PlaySoundStop ok
38305 0 Hanging up call...
38315 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
38315 0 PlaySoundStop ok
38315 0 Waiting for a call...
38315 0 fnHangupCall end
38315 0 tapie callstate IDLE 65673 0 0
38325 0 WorkingMode@Idle=
38325 0 TimeoutClear
38325 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
38325 0 tapi Reply 65775 0
39286 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
39286 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
39296 0 Initialise telephony (due to IDLE)
39296 0 tapic lineDeallocateCall(MainCall:65673) 0
39516 0 Waiting for a call...
39526 0 hLine=65690
39526 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
41639 0 tapie callstate OFFERING 65810 0 4
41649 0 tapie ring 1
44554 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
53637 0 tapie callstate IDLE 65810 0 0
53647 0 WorkingMode@Idle=Offered
53657 0 TimeoutClear
53657 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
54578 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
54578 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
54588 0 Initialise telephony (due to IDLE)
54588 0 tapic lineDeallocateCall(MainCall:65810) 0
54818 0 Waiting for a call...
54828 0 hLine=65844
54828 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
59846 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
regards
jose
Please check whethere the modem you are using is a 'Voice' modem.
If it is a Voice modem then have you installed it's Wave drivers correctly?
How do I Know that it is voice modem?
I only see Creative Modem Blaster V.90 PCI DI5655
my OS is WIN2K
regards
Jose
If it is then "Voice" will be listed in the modem's 'Features' list.
You can also just ask the manufacturer or the shop from which the modem was purchased.
