Evaluate Expression Problem
I use evaluate expression module to redirect script track.
In working script my EE module recognizing called number and following to next script, but in test (backup) server something going wrong.
EE module:
F(x) DDI - name
Expression to evaluate: $RV_DNIS
Assign result to the following RV: DDI
one of path:
on {222090625} goto [C:\Program Files (x86)\VoiceGuide\Scripts\manager\manager_main.vgs|]
data from log file look:
133436.598 6 93 31 state [DDI] Evaluate [$RV_DNIS]
133436.598 6 93 31 rv replace start [$RV_DNIS]
133436.599 6 93 31 rv replace end [222090625]
133436.599 6 93 31 eval [222090625]
133436.599 6 93 31 eval InvokeMember Eval returned
133436.599 6 93 31 rv add [DDI_Input]{222090625}
133436.599 6 93 31 d added DDI_Input | 222090625
133436.599 6 93 31 d updtd DDI_Input | 222090625
133436.599 6 93 31 rv add [DDI]{222090625}
133436.599 6 93 31 d added DDI | 222090625
133436.599 6 93 31 d updtd DDI | 222090625
133436.599 6 93 31 creating new (non-global) rv : called_DDI
133436.599 6 93 31 rv add [called_DDI]{222090625}
133436.599 6 93 31 d added called_DDI | 222090625
133436.599 6 93 31 Eval Expr result:[222090625] stored in RV[called_DDI]
133436.599 6 93 31 path {222090625} not found
133436.599 6 93 31 matching path not found [222090625], try boolean paths.
133436.599 6 93 31 ex: ScriptIo.VGMTYPE_EVALEXPR [222090625] could not be converted to boolean. Take Success path as string non-empty.
133436.599 6 93 31 matching path not found (Boolean True)
133436.599 6 93 31 HangupCall, source=Path {Success} not defined., WorkModeScript=Running_BeforeAnswerCall, yLineStateAppPov=[Offered], lPlayId=0, lRecId=0
133436.599 6 93 31 moduleTitle=[DDI]
133436.599 6 93 31 ScriptWorkingMode set Stopping, (called from HangupCall)
133436.600 6 93 31 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL)
133436.600 6 93 31 ls set ignore new linestate set as current linestate is Offered
133436.600 6 93 31 state Hanging up... [Path {Success} not defined.]
Why not working?
Can you please post the script used and the the full vgEngine trace that captures system startup and the incoming call.
Please .ZIP up traces before posting.
