Problem Upgrading To 5.1.6
i've uninstalled the 5.1.4 that was working fine and installed the 5.1.6 and now I get this error:
233820.97 0 callstate OFFERING 66030 0 4
233820.97 0 Answer the call at 12/18/2002 11:38:20 PM
233820.98 0 lineAnswer(66030) => 66013
233820.99 0 ring 1
233820.00 0 callstate ACCEPTED 66030 0 0
233824.35 0 tapi Reply (LineEvReply) ok 66013 0
233824.38 0 callstate CONNECTED 66030,0,0
233824.38 0 WorkingModeTAPI@Connected=
233824.38 0 WorkingModeScript@Connected=
233824.39 0 Inband detection not enabled
233824.41 0 StartLoadedVgs at 12/18/2002 11:38:24 PM
233824.41 0 [Welcome] Number Input
233824.44 0 [Welcome] Playing (VmailSysWelc.wav)
233824.45 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>6] file[C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
233824.46 0 PlaySoundStart line[0] err=[0 wavec waveOutOpen(0x223e24, 0x0, 0x223df0, 0x1013c, 0x223dc8, 0x10002) => 6 (MMSYSERR_NODRIVER) ... hli->hWaveOut=0x0] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
233824.51 0 Hanging up call... [srlib PlaySoundStart]
233824.53 0 RecSoundStop ok
233824.56 0 PlaySoundStop ok
233824.60 0 fnHangupCall end
233824.63 0 tapie PlayEnd old line=0 0 618024
233824.66 0 tapie PlayEnd old line=0 0 618024
233825.44 0 callstate DISCONNECTED 66030,1,0
233825.47 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
233825.51 0 Hanging up call...
233825.53 0 RecSoundStop ok
233825.56 0 PlaySoundStop ok
233825.59 0 fnHangupCall end
233825.63 0 callstate IDLE 66030 0 0
233825.66 0 WorkingMode@Idle=
233825.70 0 tapi Reply (LineEvReply) ok 65996 0
233825.73 0 tapi Reply (LineEvReply) ok 65979 0
233826.66 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
233826.70 0 ReinitTelephony due to IDLE start
233826.73 0 tapic lineDeallocateCall(MainCall:66030) 0
233826.91 0 lineOpen(0) => 0
233826.94 0 Waiting for a call...
233826.98 0 lineOpen(0)LineHandle=65962
any idea?
Looks like the Wave driver for the modem/card are not correctly installed - Please ltry re-installing your telephony device.
If after re-installing the drivers you still encounter problems can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first.
(You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager.)
But it was working perfectly! I just uninstalled your software and installed the new release again!
Installing / Uninstalling of VG should not affect the Wave drivers setup/config - VG's installer does not touch them...
The trace shows that right now on your system the error is returned by the wave driver:
waveOutOpen return error: MMSYSERR_NODRIVER
Sorry to bother you, but I'm still with the "MMSYSERR_NODRIVER" error. I've DISABLED/UNINSTALLED... I made everything you told me, the modem works perfectly and the "Unimodem Half-Duplex Audio Device" said that is "working properly".
I don't know what else do to make your software work with a modem. The modem is an internal US Robotics 3090
The error you see on your system is returned by Windows when it tries to find the wave driver for your modem - and re-installing the wave driver would usually resolve such issues...
There really isn't much else we can suggest - the wave drivers do not appear to work correctly and this needs to be resolved before VG can use the modem...
