Dialog/4 (isa) card
The unit will answer the call, but will not play any outgoing message. It will record a incoming message. I have downloaded and installed the MuLaw files.
My copy of voiceguide just expired, is there a way I can get another couple of days.....
I just got my dialogic board.
... just restart the software... demo version of VG will only work for 1 hour and then needs to be stopped and restarted to work for another hour... these restarts can be repeated indefinitely.
Wierd, I open the event logger, check the box at the bootom, "Save to File xxx.txt" but no file ever appears....
Here Are Links to some Screen Captures and a Txt File
After a call
Before a Call
Log Text
We really want to decide and buy, your support is great!
The logs are actually saved in VoiceGuide's \log\ subdirectory - the text label on the log screen is incorrect...
From the screenshot we can see what the problem with the script is:
Module "Evaluate 1" evaluates the $RV_CALLLENGTH Result Variable (we see call is has been on system for 10 seconds... ) but then there is no path from that module... if there is no "True" (or "Success") path from that module VG will hang up - which is what its doing...
PS. If you are not currently using the latest version of VG (current is v5.1.6) I'd recommend updating to that version...
Software Updated, Here is the TraceFile:
174136.97  6 ring 0
174136.98  6 Answer the call at 12/16/2003 5:41:36 PM
174136.98  6 lineAnswer(65846) => 65607
174137.54  6 callstate CONNECTED 65846,1,0
174137.55  6 WorkingModeTAPI@Connected=
174137.55  6 WorkingModeScript@Connected=
174137.66  6 Inband detection not enabled
174137.66  6 StartLoadedVgs at 12/16/2003 5:41:37 PM
174137.68  6 tapi  Reply (LineEvReply) ok 65607 0
174137.68  6 [Welcome] Number Input
174137.70  6 [Welcome] Playing ()
174137.70  6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
174139.69  6 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
174139.70  6 [Welcome] Playing ()
174139.71  6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
174141.71  6 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
174141.72  6 [Welcome] Playing ()
174141.73  6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
174143.45  6 dtmf 1  (65846,49,2)
174143.46  6 LsGetNbrsRxDigits 1
174143.47  6 [Welcome] Number Input 1
174143.48  6 path {1} not found
174143.65  6 dtmf 1  (65846,49,2)
174143.66  6 LsGetNbrsRxDigits 1
174143.67  6 [Welcome] Number Input 11
174143.68  6 path {11} not found
174143.88  6 dtmf 1  (65846,49,2)
174143.89  6 LsGetNbrsRxDigits 1
174143.90  6 [Welcome] Number Input 111
174143.91  6 path {111} not found
174144.09  6 dtmf 1  (65846,49,2)
174144.11  6 LsGetNbrsRxDigits 1
174144.13  6 [Welcome] Number Input 1111
174144.13  6 path {1111} not found
174145.13  6 dtmf #  (65846,35,2)
174145.14  6 LsGetNbrsRxDigits #
174145.14  6 path {1111} not found
174145.16  6 [Evaluate 1] Evaluate [$RV_CALLLENGTH]
174145.18  6 RVreplace start: [$RV_CALLLENGTH]
174145.19  6 RVreplace end: [8]
174145.21  6 .Eval(8)
174145.23  6 Eval Expr result:[8]
174145.23  6 path {8} not found
174145.26  6 Hanging up call... [No path (True) to next module defined.]
174145.28  6 RecSoundStop ok
174145.30  6 PlaySoundStop ok
174145.34  6 fnHangupCall end
174145.38  6 linedevstate 2048 0 0
174145.39  6 callstate IDLE 65846 0 0
174145.41  6 WorkingMode@Idle=
174145.48  6 tapi  Reply (LineEvReply) ok 65624 0
174146.41  6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
174146.43  6 ReinitTelephony due to IDLE start
174146.45  6 tapic lineDeallocateCall(MainCall:65846) 0
174146.69  6 lineOpen(6) => 0
174146.71  6 Waiting for a call...
174146.72  6 lineOpen(6)LineHandle=65863
Trace shows that the script that you are using starts at module [Welcome], but module Welcome is not set to play any sound files:
The caller then presses "1" 4 times:
and the script branches to module [Evaluate 1]
which does not have any paths leaving it:
It looks like you have not set up your script properly... I'd recommend looking at what your script again and correctly setting all the sound files that it's supposed to play and the modules' paths...
Ok, We got the script going, but when we record our own messages, it give the Error "An Error Occured While Playing the Message"
I know with the Dialogic/4 we need mu-law format files, but when we record our own, how do we genreate these files? is there a convertor?
It should record them in uLaw format - ready for playing back using the same card...
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, (rec and then play back) and also .ZIP th erecorded sound file and attach it to the post..
