Can't Hear Sound File
Traces show that an incommoding call was answered and a sound file PayGetId.wav was played.
There were no errors playing the sound file, and HMP indicated that it finished playing the sound file 8 seconds after it started - as expected.
To better see what is happening we would need to see the WireShark trace capturing the entire call. WireShark will show what actual sound was sent out over the network during the call.
Please see www.wireshark.org - download WireShark and make a trace capturing the call and .ZIP up the .pcap trace and post it here.
Please .ZIP up any trace files before posting.
195 130719.596  2156   3 ev    GCEV_OFFERED crn=8000001 (ktTel_HMP30vista v7.3.2, Nov  7 2012 23:53:38)  (setting hli->crn for line 3)
196 130719.596  2156   3       calling GetUserInfo next
197 130719.600  2156   3       RetrieveInformationElements  crn: 0x8000001
198 130719.600  2156   3       ERROR gc_GetCallInfo U_IES
199 130719.601  2156   3       gc_ErrorInfo gcValue=68(0x44), gcMsg=[invalid parameter], ccLibId=8, ccLibName=[GC_H3R_LIB], ccValue=0x5, ccMsg=[iPERR_BAD_PARAM], additionalInfo=[]
200 130719.601  2156   3       SetupMsg_Char=[]
201 130719.601  2156   3       CIPStateMachine_NullGcevOffered call
202 130719.608  2156   3       CIPStateMachine_NullGcevOffered START. sets the coders negotionation and other call paramters
203 130719.608  2156   3       RemoteEndsProposedCoders parm_data_buf=0x8794b47, parm_data_size=382
204 130719.609  2156   3       parm_data_ext: data_size=27, parm_ID=1, pData=0x8794b4c, pInternal=0x8794b47, set_ID=12315, version=256
205 130719.609  2156   3       parm_data_ext: data_size=70, parm_ID=2, pData=0x8794b6c, pInternal=0x8794b67, set_ID=12315, version=256
206 130719.609  2156   3       parm_data_ext: data_size=20, parm_ID=3, pData=0x8794bb7, pInternal=0x8794bb2, set_ID=12315, version=256
207 130719.609  2156   3       parm_data_ext: data_size=45, parm_ID=16, pData=0x8794bd0, pInternal=0x8794bcb, set_ID=12315, version=256
208 130719.609  2156   3       parm_data_ext: data_size=68, parm_ID=18, pData=0x8794c02, pInternal=0x8794bfd, set_ID=12315, version=256
209 130719.609  2156   3       parm_data_ext: data_size=36, parm_ID=19, pData=0x8794c4b, pInternal=0x8794c46, set_ID=12315, version=256
210 130719.609  2156   3       parm_data_ext: data_size=38, parm_ID=16, pData=0x8794c74, pInternal=0x8794c6f, set_ID=12300, version=256
211 130719.609  2156   3       parm_data_ext: data_size=38, parm_ID=16, pData=0x8794c9f, pInternal=0x8794c9a, set_ID=12300, version=256
212 130719.609  2156   3       gc_util_next_parm_ex returned 'There are no more parms in the GC_PARM_BLK'
213 130719.609  2156   3       SetTxRxVoiceChannelCoders begin
214 130719.609  2156   3       G711 only specified as iLicCount_EnhancedRTP=0, various frames_per_pkt settings
215 130719.609  2156   3       G711 codec order: 1:ULaw, 2:ALaw
216 130719.609  2156   3       SetTxRxVoiceChannelCoders txcoders=6, rxcoders=6
217 130719.609  2156   3       gc_SetUserInfo(GCTGT_GCLIB_CRN, 0x8000001, gcParmBlk=0xd2f63f0, GC_SINGLECALL) ok
218 130719.609  2156   3       protocol is SIP
219 130719.609  2156   3       gc_GetCallInfo ORIGINATION_ADDRESS_SIP=[sip:17772414440@callcentric.com;tag=b45ecb43]
220 130719.609  2156   3       gc_GetCallInfo DESTINATION_ADDRESS_SIP=[sip:17772426890@callcentric.com]
221 130719.610  2156   3       gc_GetCallInfo IP_CALLID=[YjUyYzAyOGZlZmVjODE2YTU3OWJlMzc2NWM3OTk0MDE.]
222 130719.610  2156   3       gc_GetCallInfo ORIGINATION_ADDRESS=[17772414440@callcentric.com]
223 130719.610  2156   3       gc_GetCallInfo DESTINATION_ADDRESS=[17772426890@callcentric.com]
224 130719.610  2156   3       OnGcEvOffered_GetCallerID call
225 130719.616  2156   3       OnGcEvOffered_GetCallerID start (with CallerID report)
226 130719.616  2156   3       OnGcEvOffered_GetCallerID gc_GetCRN: crn=0x8000001 (setting hli->crn for line 3)
227 130719.616  2156   3       gc_GetNetCRV not called in non-dialogicSR60 versions
228 130719.616  2156   3       not retrieved: CALLNAME
229 130719.616  2156   3       gc_ErrorInfo gcValue=68(0x44), gcMsg=[invalid parameter], ccLibId=8, ccLibName=[GC_H3R_LIB], ccValue=0x5, ccMsg=[iPERR_BAD_PARAM], additionalInfo=[]
230 130719.617  2156   3       ani: 17772414440@callcentric.com orig: 17772414440@callcentric.com name:  dnis: 17772426890@callcentric.com dest: 17772426890@callcentric.com
231 130719.617  2156   3       raising LINECALLSTATE_OFFERING next (with cid data)
232 130719.620  2156   3       Event_CallState GCEV_OFFERED iLineCallState=2, hCall=8000001|134217729 m_pktTelProxyClient=0022116C
233 130719.621  2156   3 r     CallState GCEV_OFFERED
234 130719.639  4848           1|10 wrote 4333 (lines=42) or=0 max=9162/95 curr=0 tesf=0
235 130719.820  2824   3 fn    AnswerCall(sXMLOptions=[])
236 130719.825  2824   3       dx_adjsv (2, SV_VOLUMETBL, SV_ABSPOS, SV_ADD4DB) default call
237 130719.826  2824   3       gc_AnswerCall crn=8000001
238 130719.901  4848           0|11 wrote 211 (lines=3) or=0 max=9162/95 curr=1 tesf=0
239 130721.234  2156   3       ev    idx=10 : evttype=2050(2050), crn=8000001
240 130721.234  2156   3 ev    GCEV_ANSWERED crn=8000001 (ktTel_HMP30vista v7.3.2, Nov  7 2012 23:53:38)
241 130721.234  2156   3       set hli->pCTelProxyhli (in GCEV_ANSWERED). current hli->pCTelProxyhli=040018A0, pTelClientEvents=040018A0
242 130721.235  2156   3       dx_setevtmsk => -1
243 130721.235  2156   3       dx_clrdigbuf => 0
244 130721.236  2156           ResetVoiceBackToItsNetwork dxxxB1C1->iptB1T1
245 130721.241  2156   3       Reset_voice_to_ipt begin. dxxxB1C1:2 to iptB1T1:3 (hli->ct_devinfo_dx.ct_devfamily=0)
246 130721.241  2156           hli->linedev=3 hli->voicedev=2
247 130721.242  2156   3       gc_GetNetCRV not called in non-dialogicSR60 versions
248 130721.242  2156   3 r     Dialogic  GCEV_ANSWERED 2050 (2050 0 0   )
249 130721.243  2156   3       Event_CallState GCEV_ANSWERED iLineCallState=256, hCall=8000001|134217729 m_pktTelProxyClient=0022116C
250 130721.243  2156   3 r     CallState GCEV_ANSWERED
251 130721.292  7432           gc_ResultInfo failed
252 130721.292  7432   3       gc_ErrorInfo gcValue=68(0x44), gcMsg=[invalid parameter], ccLibId=8, ccLibName=[GC_H3R_LIB], ccValue=0x5, ccMsg=[iPERR_BAD_PARAM], additionalInfo=[]
253 130721.295  2156   3       ev    idx=11 : evttype=2133(2133), crn=0
254 130721.295  2156   3 ev    GCEV_LISTEN (2133 0x855) no handler.
255 130721.443  4848           1|12 wrote 1409 (lines=16) or=0 max=9162/95 curr=0 tesf=0
256 130721.753  2824   3 fn    PlayStart(iLineId=3, sFileList=,C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav, sXMLOptions=)
257 130721.768  2824   3       PlayStart(hLine=3, strSoundFile=,C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav, iPlayId=678454(0xa5a36), iParam1=0, iParam2=0, zsParam1=, zsParam2=, keys-notused)
258 130721.807  2824   3       play  start (hli=0C11EEA0, strSoundFile=,C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav, iPlayId=678454(0xa5a36), iParam1=0, iParam2=0, zsParam1=, zsParam2=)
259 130721.809  2824   3       play  readin loop: idx=0/500, fnamelen=68
260 130721.824  2824           wav: format=7, channels=1, hz=8000, bytes/sec=8000, bytes/sample=1, bits/sample=8, DataBlockSize=66787  C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav
261 130721.824  2824   3       iXpbSampleRateDRT_FirstFile = DRT_8KHZ
262 130721.824  2824   3       iXpbBitsPerSample_FirstFile = 8 (as per returned data)
263 130721.824  2824   3       XpbDataFormat: DATA_FORMAT_MULAW, rate_const=0x40, bits=8 (iWavFilesEncodingFormat_LastFile=7)
264 130721.825  2824   3       buffer merge add loop hPlayIott_Curr=0x3c4dcb8, ptrVoiceData=0x40587e0, io_bufp=0x40482e8, io_length=66785
265 130721.825  2824   3       buffer merge end. calc=66785, copied=66785. hPlayIott_Start=0x3c4dcb8
266 130721.825  2824   3       dx_setevtmsk dev=2 => 0
267 130721.825  2824   3       dx_clrsvcond dev=2 => 0
268 130721.825  2824   3       dx_adjsv dev=2, speed, reset => 0 (no speed keys set on play)
269 130721.825  2824   3       play  xpb: wDataFormat=7, wFileFormat=1, nSamplesPerSec=0x40, wBitsPerSample=8 ()
270 130721.825  2824   3       play(2, iott=0x3c4dcb8 (len=66785, buff=0x40587e0), tpt=0x0, xpb=0xc122ba4) call
271 130721.825  2824   3       play(2, 0x3c4dcb8, tpt=0x0, xpb=0xc122ba4) => 0, hli=0C11EEA0
272 130721.862  4848           0|13 wrote 1910 (lines=16) or=0 max=9162/95 curr=1 tesf=0
273 130730.306  2156   2       ev    idx=12 : evttype=129(129), crn=0
274 130730.318  2156   2 ev    TDX_PLAY (Play Completed)
WireShark trace shows an outgoing call from this system made to 17772426890@callcentric.com using X-Lite.
Soon after there is call coming into the system from a CallCentric IP, with destination being 17772426890@callcentric.com.
You should not be using more the one SIP application on a system. They interfere with each other as they both try to use same SIP port.
Please remove X-Lite and all other SIP applications apart from HMP+VoiceGuide from this system and then test again, making call to 17772426890@callcentric.com from another system or phone.
Hello,
I have removed my sip applications oovoo and x-lite from my computer.
I dial the vg7 HMP sip number from another laptop, but still the problem was existed.
I bought a DID number form Callcentric and forward it to the my VG SIP number. I dial the DID number by my mobile, but still there was no sound out of script.
please see attached the wireshark and vg log fine for all of above test process.
log.zip
Attached WireShark trace shows no RTP of any kind. Neither incoming nor outgoing RTP is included.
Maybe the previously installed SIP applications did not fully uninstall and are still affecting operation.
Perhaps the quickest way to resolve this would be to reformat the system and reinstall Windows and the just install HMP and VoiceGuide on the system.
Hello,
I have used Cclean to clean up my registry. after rebooting everything works fine.
many thanks for your help.
Farzad
