Vg With Hmp Over Avaya System
We need to build the following system for one of our IVR customers, and I would like to make sure that it is a supported configuration by Voiceguide7.
Windows2008 + VG7 + Dialogic HMP driver for VoIP over AVAYA (Notell) CS1000 using SIP protocol.
I believe there should be no problem, but wanted to double check with the experts.
Thank you!
Thanks for confirmation.
How many SIP channels would you like to run on this server?
We are not sure as the AVAYA will be running on our customer's end.
Is there any limit on the number of channels?
We were referring to the number of simultaneous calls the IVR will be expected to handle.
If it is more the about 300 simultaneous calls (exact number depends on type of application being ran)then we may want look at the detailed server specifications (CPU, chipset, memory, etc) to make sure it can handle the load.
A VoiceGuide license and a HMP license would need to be purchased for every channel, so the number of channels (maximum simultaneous calls handled by system) would need to be established when deploying the system.
