How To Test The Developed Script
I am very new to voiceguide, so please bear with me.
I have developed a new script(very small) and wanted to test it, please let me know how can i test it without connecting external device(like phone).
Regards
Sunil Negi
Usual testing approach is to set up VoiceGuide v7 in VoIP mode, and dial into system from another computer using a softphone.
eg: with SJPhone you can just dial the IP address of the machine on which VoiceGuide is installed.
See: http://www.sjlabs.com/sjp.html
When the IP address of the machine on which VoiceGuide is installed is called form a SIP VoIP phone/softphone then VoiceGuide will answer that call and run the script specified in Config.xml
No other configuration is necessary. Just make a call to the IP address of the machine on which VoiceGuide is installed.
