Hmp Voip Menu
Hello,
I have successfuly installed the VG7 and HMP Dilogic driver.
I can not find VG7 and HMP Dilogic's menu to find out how to call into the Vg7 VoIP (no telephony cards required)?
Would you please advise me?
To cal into system you need to use a SIP phone (or softphone on another computer) and the just dial the IP address of the system on which HMP/VoiceGuide is installed.
You need to ensure that the firewall allows external calls in (or just disable firewall during testing if not sure how to set it to allow SIP calls through).
One softphone you could use is SJPhone (see: http://www.sjlabs.com/sjp.html )
