Issuing multiple API calls in one module
How to combine in one module:
- setting the $RV[DoNotStopMOH] to 0
- stop the Play moh
- start play prompt
BTW.
Is possible to back previous available functionality that stop MoH when module include other playable prompts?
You can try the below.
You need to have the module from which you issue this combination of API calls wait until the script completes.
et vg = CreateObject("vgServices.CommandLink")
vg.RvSet $RV_LINEID, "DoNotStopMOH", "0"
vg.Play_Stop $RV_LINEID
vg.Play_Start $RV_LINEID, "c:\mypath\prompt.wav"
set vg = Nothing
How to integrate
  • Clear the $RV[DoNotStopMOH] flag (set the $RV[DoNotStopMOH] to 0)
  • Then stop the Play
in one VBS module?
in previous versions of VG it wan unnecessary to set DoNotStopMOH to 0 value before "vg.Play_Stop $RV_LINEID"
set vg = Nothing
You should be able to still issue Play_Stop API call regardless of what value the $RV[DoNotStopMOH] is set to.
