Variables In $Rv
New to voice guide-
I was wondering is it possible to use a variable within a $RV-
I am running a sql query against a access db where the return results could be more than one row. I then want to present the results to the user and allow them to pick which item they want (which will then trigger a second sql query).
Since I don't know how many rows will be returned, how can I use the $RV to get the results to read? something like
$RV[LookUpProduct_1_x]
where x is a counter that will be incremented and looped through, stopping once there are no rows left.
Is this possible? I don't see anything like that in any of the samples.
Also another question, can the Play_Start in a VB script be used to read the contents of a text file instead of playing a wav?
Thanks!
Mike
Yes. This is possible.
Use:
$RV[LookUpProduct_1_$RV[someCounter]]
where $RV[someCounter] is your counter $RV.
You can have deeper nesting of $RVs and multiple $RVs on same line etc.
Yes, it can. Just specify the .txt file and its contents will be TTSd.
Please let us know if you have any questions.
