Extracting data from log file
I need hints how to extract needed data from log file.
When I try to find data in log file I can't identify one connection (in and out trays) to analyze or to send you to forum.
Have you any tool to extract single connection data?
In both the VgEngine and ktTel trace files there is columns that indicates the port id/number for which this log entry is made.
This is usually used to extract entries in log file related to particular port, and hence a particular call.
grep is one too that can be used to extract port specific trace entries.
See:
http://gnuwin32.sourceforge.net/packages/grep.htm
http://www.powergrep.com/grep.html
