VBScript not running PlayStop API call
I have problem with playing module when
I try to connect with first available target.
problem is that not working VG module:
vg.Play_Stop $RV_LINEID
set vg = Nothing
VG not playing:
093840.740 27 23 8 rv replace end [manager4\60556.wav]
but still:
093836.147 6 23 8 FindSoundFile start [C:\Program Files\VoiceGuide\Scripts\manager\komunikaty\ring_multiple.wav]
I attached example of script.
How to set up loop with:
1. not stopping Transfer MoH when no available prompt about target
2. stopping MoH and playing prompt about target when it's available (declared)?
20120913 PLAY module.zip
connecting loop.zip
Traces show that the VBS script did not run.
Have you tried running the .vbs file that was created in the VoiceGuide's \temp\ subdirectory to see if script runs when the actual .VBS file is ran?
Could be a typo in the VB script itself, or permission settings are not allowing script to run, or not allowing vgServices.CommandLink objects to be created.
This can be caused by anti-virus apps etc.
Also, it looks like the VoiceGuide script is set to continue after the VBScript is queued to be started.
If VoiceGuide script is set to start any VBScripts that call VoiceGuide APIs, the VoiceGuide script should wait for VBS to complete before proceeding.
I had problems when before Play.Stop command wasn't Play module.
In my scripts some modules before transfer script has no MoH and then I had problems with next play modules.
I diversed trace when modules using MoH or not. In first case I addressed trace to PLAY.Stop VBS module, in second to next one.
Can Play.Stop module working only when before was Play module or MoH? Otherwise ignoring function.
It doe snot matter what module follows - but you should make sure that if VoiceGuide script is set to start any VBScripts that call VoiceGuide APIs, the VoiceGuide script should wait for VBS to complete before proceeding.
