D/4pci In Uk With Bt Lines?
Is anyone using a D/4PCI card in the UK on BT lines and using disconnect tones successfully? Could you post the config file ie go to control panel, click on phone settings, Advanced tab, select Dialogic Generation 2 Service Provider for NT, Click Configure, then Advanced and finally Save As Text (bottom right corner of window)
Many thanks
Hi I am having some real problems with disconnect tones using this card, did you get a response from any one if so could I also have a copy of the file. Please send it to barry@pocket-link.com
Many thanks
Barry Holleran
Please record the disconnect tone (Using a "Record" module within VoiceGuide) and .ZIP up and post the recorded sound file.
