Substring
Hello,
Is there any posibilitz to make and and substring from the $RV_CIDNUMBER
If the CIDNUMBER starts with 3911 then take an other route if not then the default route. Is it possible to make it with Evaluate expression?
Whats the Error 13?
here is the log:
180823,05 8 StartLoadedVgs at 05.12.2003 18:08:23
180823,05 8 [check language] Evaluate [substring("$RV_CIDNUMBER",1,4)]
180823,06 8 RVreplace start: [substring("$RV_CIDNUMBER",1,4)]
180823,06 8 RVreplace end: [substring("3911234567",1,4)]
180823,07 8 .Eval(substring("3911234567",1,4))
180823,07 8 Error: 13
180823,08 8 Eval Expr result:[substring("3911234567",1,4)] stored in $RV[turha]
180823,08 8 path {substring("3911234567",1,4)} not found
BR Jukka
I believe you can use all the Result Variables in the Evaluate Expression module, may be try this expression:
($RV_CIDNUMBER >= 3911000000) and ($RV_CIDNUMBER <= 3911999999)
then under Paths,
[True] goto [route#1]
[False] goto [next module]
Something like that.
Hope this help.
you can also use the following in an Evaluate Expression module:
left("$RV_CIDNUMBER", 4))
then you can use paths like these:
on {3911} goto [Play 1]
on {true} goto [Play 2]
