Caller Id
I need to use the Caller ID that has been saved in the excel sheet.
May I know what is the command (or procedures) to go about getting the numbers so that I can use it in other modules.
If you just want to use the current Caller ID, then $RV_CIDNUMBER should work fine in any modules.
If you somehow saved a list of Caller ID, then may I suggest you to use the Database Query module, you can save or retrieve your Caller ID using that module.
Hope this help.
