Open *.vgs File
I use evaluate version VoiceGuide v7.3.2.
After I close my *.vgs file.I try to reopen it ,but failed.says "*.vgs file could not be loaded ".How can i solve this problem?
Can you please .ZIP up and post the .vgs file that you are having trouble opening?
Neither VoiceGuide application or the VoiceGuide Script Designer, or any of the other VoiceGuide tools/utilities ever lock the .vgs/.vgp file.
The .vgs/.vgp file are opened for reading/writing only and do not continue to be opened/locked.
If you were having problems opening the file then some other application other then VoiceGuide must have been using it and locked it.
