Say Numbers Error
I am trying to use the say number module in a script, and I keep getting the following:
184908.11 8 [LiveAnswer] Say numbers: 123456789 as Digits
184908.11 8 fn PlaySoundStartNumbers C:\Wave\Spinnaker\JPALLAM.wav, C:\Wave\Spinnaker\TMALLLA.wav, 123456789, Digits
184908.11 8 ERROR 5.1.2076 RunModule:0:76:Path not found:VoiceGuide
184908.12 8 Hanging up call... [RunModule Error]
I have installed all Windows updates, and Microsoft Speach SDK 5.1. Is there something else I need to install? I am using version 5.1.2076 Professional. Let me know if you need additional information.
Not too sure which SayNumber scripts were shipped with v5.1.2076 - but it looks like a problem with the lib_num2wav.vbs (SayNumber) script... can you please update your install to current release (v5.1.4 or later) and try this again...
Best to install v5.1.4 in a different directory - or delete the entire directory tree after uninstalling the current version...
I uninstalled 5.1.2, remove the directory from program files, and installed the 5.1.4 download. I replicated the script in upgraded version's script builder and noticed a box asking to "save changes to module" which I had never seen before. Now, the script gets to the say numbers module and just sits there until you push a number on the telephone keypad. It won't play wav files or speak numbers. The play wav file module works fine, so I don't think the sound is the problem. I have attached this script, but to run it you will need to set up the ODBC datasource, ect..
spinnakerconcierge3.vgs
Just tested it and confirmed that there were no problems with it playing digits when using v5.1.4
Here is a trace produced on the test machine (saying 1234 as digits):
093509.72  6 [say Numbers 1] Say numbers: 1234 as Digits
093509.72  6 fn    PlaySoundStartNumbers , , 1234, Digits
093509.72  6 sVbsFunctionToUse=Digits
093509.84  6 Started SayNumber VBScript OK. (C:\ProjectsBak\vg32 5.1.3\data\vbs_6_SayNumber.vbs)
093509.84  6 callinfo MONITORMODES
093509.98  6 cl    Play_Start 1.wav,2.wav,3.wav,4.wav
093510.86  6 PlaySoundStart ok [C:\ProjectsBak\vg32 5.1.3\system\voice\1.wav,C:\ProjectsBak\vg32 5.1.3\system\voice\2.wav,C:\ProjectsBak\vg32 5.1.3\system\voice\3.wav,C:\ProjectsBak\vg32 5.1.3\system\voice\4.wav]
093510.86  6 TimeoutClear
093510.86  6 wa(2944,25679603)
093510.88  6 callinfo MONITORMODES
093513.88  6 Play End line[6] (id=256796)
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem on your system, this will allow us to see what is going wrong.
Here the log. What release of the Microsoft Speach SDK are you running? I'm using 5.1 and it's ot working. It just hangs and doesn't say anything.
165857.67 0 ERROR 5.1.3310 DialListDbFindDueCall [invalid use of Null]
165857.71 0 dial callque update id=21 next call time 0312101858
165857.72 0 dial callque DB update returned
165857.73 8 dial found entry: tel[18015463517] ann[NONE] vgs[C:\DBLogging\spinnakerconcierge3.vgs] am[C:\Wave\Spinnaker\KCALLAM2.wav]
165857.75 8 Calling MakeCallEx(18015463517)
165857.00 8 Dialing: 18015463517
165857.00 8 MakeCall => 65757
165857.00 8 TapiCbTrigSet 65757 7002
165904.94 8 tapi Reply (LineEvReply) ok 65757 0
165904.94 8 TapiCbTrigClear
165904.95 8 linedevstate 2048 0 0
165904.97 8 callstate CONNECTED 65723,1,0
165904.97 8 WorkingModeTAPI@Connected=
165904.97 8 WorkingModeScript@Connected=
165905.06 0 dial callque delete id=21
165905.08 8 Live person answered, starting C:\DBLogging\spinnakerconcierge3.vgs
165905.10 0 LoadedVgs_Find C:\DBLogging\spinnakerconcierge3.vgs at idx=1
165905.12 8 cl NewVgsVgm_RunModule module not found:
165905.14 8 [set Silence Length] Evaluate [12]
165905.16 8 .Eval(12)
165905.19 8 Eval Expr result:[12] stored in $RV[silencedetectlen]
165905.19 8 Calling TapiWrap1.SilenceDetectSet(8, 12, 10)
165905.22 8 path {12} not found
165905.25 8 [RecAnswer] Recording
165905.26 8 RVreplace start: [RecAnswer_$RV_DEVICEID.wav]
165905.26 8 RVreplace end: [RecAnswer_8.wav]
165905.75 8 RecSoundStart file[C:\DBLogging\RecAnswer_8.wav] ok
165905.75 8 RecFile[C:\DBLogging\RecAnswer_8.wav]
165906.95 8 monitortone 1
165906.96 8 LsRecRecording EV_SILENCE_DETECTED
165906.96 8 Silence Detected while recording.
165907.02 8 rec length RV: RecAnswer_RecLen100ms = 5
165907.04 8 [AMorLA] Evaluate [$RV[RecAnswer_RecLen100ms] > 40]
165907.05 8 RVreplace start: [$RV[RecAnswer_RecLen100ms] > 40]
165907.05 8 RVreplace end: [5 > 40]
165907.05 8 .Eval(5 > 40)
165907.08 8 Eval Expr result:[False] stored in $RV[LAAM]
165907.08 8 [LA Log] DB Query
165907.09 8 ODBC mode used
165907.75 8 RVreplace start (strlen>100)
165907.75 8 About to execute Action Query
165907.79 8 [Live Answer] Say numbers: 123 as Digits
165907.80 8 fn PlaySoundStartNumbers , , 123, Digits
165907.85 8 sVbsFunctionToUse=Digits
165908.02 8 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_8_SayNumber.vbs)
165908.32 8 cl Play_Start 1.wav,2.wav,3.wav
170100.04 8 callstate DISCONNECTED 65723,1,0
170100.04 8 LsSayNbrPlay EV_REMOTEPARTY_DISCONNECT
170100.04 8 Hanging up call...
170100.04 8 RecSoundStop ok
170100.05 8 PlaySoundStop ok
170100.05 8 HangupCall : lCallHandle& = 0 - lets close and open line
170100.05 8 ReinitTelephony due to IDLE start
170100.27 8 lineOpen(8) => 0
170100.27 8 Waiting for a call...
170100.27 8 lineOpen(8)LineHandle=65706
170100.27 8 fnHangupCall end
The Say Number module is not using SAPI TTS (Text To Speech). It plays the number by playing the pre-recorded sound files which came with VoiceGuide and are in VoiceGuide's \system\voice\ subdirectory.
I'm not too sure at this stage why it's not working on your system... it's all working fine on our test systems and we have recently fielded a minor bug report from a user who was using v5.1.4 to Say Numbers as well..(See post: http://voiceguide.com/forums/index.php?showtopic=931)
BTW:
If you would like to have the number spoken using Text-To-Speech then you should specify what you need TTS'd in the "Text To Speak" box in a Play module.
Turns out there was a bug which affected outbound calls only - but not incoming calls.
Please update your 5.1.4 (or 5.1.5) install with attached .exe and try again.
VgMulti.zip
I noticed a 5.1.6 posted on your website. Is this the VgMulti from that version? I have the speak numbers module working now, but still cannot get the TTS in the Play module to work. I tried entering text in the TTS box as well as creating a .txt file, and neither worked. What should be in the .txt file for TTS to read it correctly? Do I need single, double, or no quotes in the TTS box in the Play module?
Yes.
Are you using an Enterprise version of VoiceGuide? Only Enterprise (& Evaluation) can do Text To Speech.
No quotes or anything is required - just the text itself..
That explains it. We're using the Professional version. Thanks for the help, what should work does!
