Dialing Speed?
Hi, I'm wondering if there's a way to slow down the dialing speed of $RV in Play module, so an other system can recognise the touch tones?
That speed is determined by the Dialogic card or voice modem itself....
When using the Dialogic card this settings can be adjusted in the TSP configuration - with a voice modem it's a bit harder - you will have to edit the modem's .inf driver file to set correct AT command which would set the tone length...
You can also just try specifying commas in between every tone - this should work for Dialogic but may not work for Voice Modems...
Alternatively you may have to build a series of Play modules, - each playing just one tone...
