Return Data
In Run VBS module,I write this script .
I want to read data form a Excel,and I think it could return to VoiceGuide ,so that I could use SayNum module to say it.
but unluck,it only read "value1" not read the data in this value1.
how coulde i do this? and it possible?
dim objExcel
set objExcel=CreateObject("Excel.Application")
dim filename
filename="D:\Book1.xls"
dim objWorkbooks
set objWorkbooks=objExcel.WorkBooks.Open(filename)
dim objSheet
set objSheet=objWorkbooks.Sheets("Sheet1")
dim value1
dim value2
value1=objSheet.Cells(3,2)
objWorkbooks.Close
objExcel.Quit
dim vg
set vg=CreateObject("vgServices.CommandLink")
vg.Run_ResultReturn $RV_LINEID , "[PhoneNum] {value1}"
set vg=Nothing
set objExcel=Nothing
set objWorkbooks=Nothing
set objSheet=Nothing
The Run_ResultReturn call should use string concatenation to include any variables created in the script.
your current script has this:
The above will result in $RV[PhoneNum] holding value "value1".
Change the Run_ResultReturn in your script to:
vg.Run_ResultReturn $RV_LINEID , "[PhoneNum]{" & value1 & "}"
This will place he value of the value1 variable into the script returned to VoiceGuide.
