Paging
Hi there,
I'm using enterprise version with dialer 4line version 5.1.3 on winXP.
We are trying to using the script properties on our main script to call another script when it ends.
The end script has a module that just make a paging.
When the main script finishes, the end script did not run.
Hi Support,
I've managed to get the call traced and attached is the log file.
I think I saw the problem.... the log says that to purchase the VG dialer
add-on in order to enable this feature.
My colleague has recently purchased VoiceGuide and it includes the dialer.
Company: Ngee Ann Polytechnic
Hear from you,
Keith
call.txt
When you select "About VoiceGuide" what license type is displayed?
a new registration code was emailed just in case to the email addresses in our client database...
Hi there,
Thank you for the prompt response in this forum.
I managed to get the new reg. code and after re-reg. the problem is still
the same :(
Attached is the 2nd call log file.
Our licence displayed Verson 5.1.3305 Enterprise, VG Dialer, 4 line license
I've already check the box under
"Menu > View > Line Device Config"
to allow voiceguide to dialout on this line
Problem:
The 2nd paging vgs didnt run as configured under my main vgs
"script properties > script to run when call is finished"
The full path to 2nd vgs is placed there.
FYI:
My main vgs ends with a goodbye sound file message and hangup the call.
My 2nd vgs is just a Send pager message.
Any suggestion?
call2.txt
