Transfer Call To Outside No Or Cell No - Via Modem
Have tried everything to get call transferred using Modem - Call Does get transferred but back to the same internal line - I'd like it go to a cell (an external no). Any help is greatly appreciated
Are you using a PBX or the Telephone Company’s lines? Is your modem's hookflash length matched to what is expected on the line which is plugged into it?
I'm using the Phone Company's lines , have tried to contact them about the hookflash length - but got now where with them. Is there any other way to find out what that is ? Thanks
Here is the log generated - Notice it runs through the whole script then hangs up as it should - but actually brings caller back to the welcome module and does it all over again.
Help is appreciated - Thanx
142032.91 0 callstate OFFERING 65933 0 4
142032.95 0 Answer the call at 1/20/2004 2:20:32 PM
142032.96 0 lineAnswer(65933) => 65797
142032.96 0 ring 1
142032.96 0 callstate ACCEPTED 65933 0 0
142034.22 0 Lev_CallerID [4162446303,NEXUS IT]
142034.23 0 Lev_CallerID [4162446303,NEXUS IT]
142037.05 0 tapi Reply (LineEvReply) ok 65797 0
142037.06 0 callstate CONNECTED 65933,0,0
142037.06 0 WorkingModeTAPI@Connected=
142037.06 0 WorkingModeScript@Connected=
142037.07 0 Inband detection not enabled
142037.09 0 StartLoadedVgs at 1/20/2004 2:20:37 PM
142037.09 0 [Welcome] Playing
142037.09 0 [Welcome] Playing (C:\Program Files\VoiceGuide\Voice\other.wav)
142037.18 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Voice\other.wav]
142037.19 0 RunModule PLAY end
142041.60 0 dtmf 2 (65933,50,2)
142041.60 0 LsPlayMsg 2
142041.70 0 PlaySoundStop ok
142042.11 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
142042.11 0 [sales] Blind Transfer to 4166887067 (Generate)
142042.13 0 tapic lineGenerateDigits(65933,!,0) => 0
142042.64 0 generate LINEGENERATETERM_DONE
142043.64 0 LsXferStart EV_TAPI_GENERATE
142044.64 0 LsXferPlayVts EV_HOOKFLASHFINISHED
142044.64 0 tapic lineGenerateDigits(65933,4166887067,0) => 0
142048.18 0 generate LINEGENERATETERM_DONE
142049.16 0 LsXferPlayVts EV_TAPI_GENERATE
142050.16 0 LsXferPlayVts EV_TIMEOUT_HANGUP
142050.18 0 Hanging up call...
142050.19 0 RecSoundStop ok
142050.19 0 PlaySoundStop ok
142050.19 0 fnHangupCall end
142050.29 0 callstate DISCONNECTED 65933,1,0
142050.30 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
142050.30 0 Hanging up call...
142050.31 0 RecSoundStop ok
142050.31 0 PlaySoundStop ok
142050.31 0 fnHangupCall end
142050.32 0 callstate IDLE 65933 0 0
142050.32 0 WorkingMode@Idle=
142050.34 0 tapi Reply (LineEvReply) ok 65729 0
142050.34 0 tapi Reply (LineEvReply) ok 65746 0
142051.25 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
142051.25 0 ReinitTelephony due to IDLE start
142051.26 0 tapic lineDeallocateCall(MainCall:65933) 0
142051.55 0 lineOpen(0) => 0
142051.56 0 Waiting for a call...
142051.56 0 lineOpen(0)LineHandle=65609
142056.32 0 callstate OFFERING 66515 0 4
142056.33 0 Answer the call at 1/20/2004 2:20:56 PM
142056.33 0 lineAnswer(66515) => 65694
142056.34 0 ring 1
142056.34 0 callstate ACCEPTED 66515 0 0
142100.46 0 tapi Reply (LineEvReply) ok 65694 0
142100.46 0 callstate CONNECTED 66515,0,0
142100.46 0 WorkingModeTAPI@Connected=
142100.48 0 WorkingModeScript@Connected=
142100.48 0 Inband detection not enabled
142100.48 0 StartLoadedVgs at 1/20/2004 2:21:00 PM
142100.48 0 [Welcome] Playing
142100.48 0 [Welcome] Playing (C:\Program Files\VoiceGuide\Voice\other.wav)
142100.57 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Voice\other.wav]
142100.57 0 RunModule PLAY end
142103.78 0 dtmf 2 (66515,50,2)
142103.79 0 LsPlayMsg 2
142103.89 0 PlaySoundStop ok
142104.29 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
142104.29 0 [sales] Blind Transfer to 4166887067 (Generate)
142104.30 0 tapic lineGenerateDigits(66515,!,0) => 0
142104.82 0 generate LINEGENERATETERM_DONE
142105.80 0 LsXferStart EV_TAPI_GENERATE
142106.80 0 LsXferPlayVts EV_HOOKFLASHFINISHED
142106.80 0 tapic lineGenerateDigits(66515,4166887067,0) => 0
142110.34 0 generate LINEGENERATETERM_DONE
142111.32 0 LsXferPlayVts EV_TAPI_GENERATE
142112.32 0 LsXferPlayVts EV_TIMEOUT_HANGUP
142112.32 0 Hanging up call...
From the trace we can see that VoiceGuide makes the transfer and then hangs up:
but then about 6 seconds later the PBX rings VoiceGuide's extension again:
142056.34 0 ring 1
This is probably because transfer to "4166887067" failed... many PBXs/switches will ring the extension from which transfer was made again if the transfer has failed and connect the original call again...
When there is a ring on a line VG trats it as a new call - that's why the script starts at the [Welcome] module again...
So is it something in the script , the hookflash lenght or some other phone company issue ?
Sam.
I am also curious about this same issue. I have had no luck transferring to an outside line using the telephone companies lines.
Any information on the subject would be REALLY appreciated!
In this case it looks liek the call was sent back to VG by the phone company - the hookflash length is OK and script worked OK as well:
Please see: http://voiceguide.com/forums/index.php?showtopic=1050
