Vg Dialer Questions
Hi all,
I have some questions about vg Dialer.
I use this xml list number loader (this is an ex.):
<OutDialEntry>
<PhoneNumber>0,MyMobileNumber</PhoneNumber>
<CallTime>27/11/2003 14:29:00</CallTime>
<DayTimeStart>0800</DayTimeStart>
<DayTimeStop>2100</DayTimeStop>
<DaysCallAllowed>MoTuWeThFrSaSu</DaysCallAllowed>
<AnnounceMessage>none</AnnounceMessage>
<OnAnswer>C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav</OnAnswer>
<OnAnswerMachine>C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav</OnAnswerMachine>
<AnswerTimeout>60</AnswerTimeout>
<CallRetries>0</CallRetries>
<RetryDelay>0</RetryDelay>
<RV></RV>
<OnNotConnected></OnNotConnected>
<Escalation></Escalation>
</OutDialEntry>
1 - Why did it find that a machine is answering when actually a human is answering to the call?
2 - Why did it wait (about 5 sec.) at the end of the <AnnounceMessage> if in my xml the <AnnounceMessage> tag is "none"?
This is the "call log"...
142838,70 0 sys cleanup Start
142838,70 0 sys cleanup End
142900,71 0 dial callque update id=533 next call time 0311271431
142900,71 0 dial callque DB update returned
142900,73 5 dial found entry: tel[0,MyMobileNumber] ann[None] vgs[C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav] am[C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav]
142900,73 5 Calling MakeCallEx(0,MyMobileNumber)
142900,73 5 Dialing: 0,MyNumber
142900,73 5 MakeCall => 66101
142900,73 5 TapiCbTrigSet 66101 7002
142901,48 5 tapi Reply (LineEvReply) ok 66101 0
142901,48 5 TapiCbTrigClear
142901,48 5 linedevstate 2048 0 0
142901,48 5 callstate DIALTONE 66357 0 0
142901,48 5 callstate DIALING 66357 0 0
142901,48 5 callstate PROCEEDING 66357 0 0
142901,50 5 callinfo CALLEDID
142901,50 5 callinfo REASON
142901,50 5 Lev_CallerID [0000,]
142901,50 5 callinfo ORIGIN
142916,02 5 callstate DISCONNECTED 66357,16,0
142916,03 5 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
142916,03 0 dial callque delete id=533
142916,04 5 AM - wait for end of welcome message...
142916,05 5 dial awaiting end of answering machine message (lvl:10 for 20)
142916,08 5 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_5.wav] ok
142923,64 5 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
142924,65 5 RecSoundStop ok
142924,66 5 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
142924,66 5 Play Answer Machine message [C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav]
142924,68 5 PlaySoundStart ok [C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav]
142948,63 5 wb(17147300)
142949,64 5 Play End line[5] (id=171473)
142949,64 5 LsDialoutPlayOnAnswerMachine EV_PLAY_FINISHED
142949,64 5 Hanging up call... [LsDialoutPlayOnAnswerMachine 2 ]
142949,64 5 RecSoundStop ok
142949,64 5 PlaySoundStop ok
142949,66 5 Waiting for a call...
142949,66 5 fnHangupCall end
142949,70 5 linedevstate 2048 0 0
142949,71 5 callstate IDLE 66357 0 0
142949,71 5 WorkingMode@Idle=
142949,71 5 LineState(iLineId).iVgsIdx = 0
142949,71 5 tapi Reply (LineEvReply) ok 66340 0
142950,67 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
142950,67 5 ReinitTelephony due to IDLE start
142950,68 5 tapic lineDeallocateCall(MainCall:66357) 0
142950,85 5 lineOpen(5) => 0
142950,85 5 Waiting for a call...
142950,86 5 lineOpen(5)LineHandle=66067
I wait your answers as soon as possible.
Tnx.
Some mobile phone networks have poor sound quality - and in these cases the Dialogic card may mistake a human answering the call for an answering machine.
If the Dialogic card indicates that an answering machine has answered a call then VoiceGuide will wait until there is silence on the line before it will start playing the Answering Machine message. This is what we are seeing here:
To see what was recorded see the file:
ok thanks.
Other two questions for you:
1-Can I disable the EV_SILENCE_DETECTED in some way?
2-There is a maximum number of files that can be selected to be played one after another in <OnAnswer> and <OnAnswerMachine>?
tnx
yes, in VG.INI - but I think what you actually are asking about is to disable Answering Machine detection... please update your v5.1.3 installation with attached VGMULTI.EXE , and then type IGNORE in the Answering Machine Message field... then the normal script will be started when an Answering Machine is detected answering the call..
No, you should be able to specify as many comma delimited files as you like...
VgMulti.zip
