Transfer Module Playing Not Connecting
I created new module to prepare call to transfer and results follow to transfer call script.
With old preparing script transfer script working properly-connecting, but with new don't.
With old script Transfer Call module playing MoH but not transferring.
48825 083938.468 20 5 2 FindNextVgmTitleInPathList: next module title is=[Transfer Call fa]
48826 083938.468 20 5 2 RunModule_AddToTaskQueue [Transfer Call,[Transfer Call fa],285]
48827 083938.468 20 5 2 q scr add evScriptEvent 9800 CMD_RUN_SAME_MODULE_AGAIN
48828 083938.468 20 5 2 db odbc query completed.
48829 083938.468 6 5 2 q scr run evScriptEvent sCode=[CMD_RUN_SAME_MODULE_AGAIN] iActionID=0, crn=0[0|0|0|0|0][|||||] 54|00:00:05.1875000
48830 083938.468 6 5 2 scriptevent CMD_RUN_SAME_MODULE_AGAIN 0|0|0 || LineState=LS_DBQUERY
48831 083938.468 6 5 2 t timer clear (force=False)
48832 083938.468 6 5 2 RunModule start Transfer Call, [Transfer Call fa], iModuleIdx=285, previous: vgm=285, vgs=7:7
48833 083938.468 6 5 2 rv replace start [$RV[insert_call_order_telefon1_$RV[kolejnosc]]]
48834 083938.468 6 5 2 rv replace end [224571444]
48835 083938.468 6 5 2 t timer set 0,4 sec : EV_TIMEOUT_READYTOBEGINTRANSFER
48836 083938.515 21 remoting link constructor activated: vgServices_CommandLink
48837 083938.515 13 remoting link constructor activated: vgServices_CommandLink
48838 083938.531 21 5 2 rem Play_Stop
48839 083938.531 21 5 2 CallExistsOnLine TRUE crn=280037c
48840 083938.531 21 5 2 q scr add cmdPlayStop 0
48841 083938.531 6 5 2 q scr run cmdPlayStop sCode=[] iActionID=0, crn=0[0|0|0|0|0][|||||] 54|00:00:05.1875000
48842 083938.531 6 5 2 q tel add cmd_PlayStop [0,0,0,0,0][||||]
48843 083938.531 6 5 2 play PlaySoundStop ok
48844 083938.531 7 5 2 q tel run cmd_PlayStop 5|00:00:02.3437500
48845 083938.531 21 5 2 rem Play_Start komunikaty\ring_multiple.wav
48846 083938.531 21 5 2 CallExistsOnLine TRUE crn=280037c
48847 083938.531 21 5 2 q scr add cmdPlayWavTts 0
48848 083938.531 6 5 2 q scr run cmdPlayWavTts sCode=[] iActionID=0, crn=0[285|0|0|0|0][komunikaty\ring_multiple.wav|||||] 54|00:00:05.1875000
48849 083938.531 6 5 2 PrepareAndPlayWavAndTts start iModuleIdx=285, iPlayFileIdx=0, bMakeTtsFile=True, sSoundFileIs=komunikaty\ring_multiple.wav
48850 083938.531 6 5 2 PrepareAndPlayWavAndTTS sPlayFile=komunikaty\ring_multiple.wav
48851 083938.531 6 5 2 state [Transfer Call fa] Playing wav (komunikaty\ring_multiple.wav)
48852 083938.531 6 5 2 FindSoundFile start [komunikaty\ring_multiple.wav]
I attached log file (changed in excel to extract needed logs) (first column is order column)
Any tips to extract one connection logs from log file to send You to analyze?
0814_0831_vgEngine play not connected.zip
Could you please upload the ktTel excerpt that covers the time from 08:35:00 till 08:40:00
Please update system to this version of VoiceGuide:
[old link removed]
and post traces when this new version is used.
