Loop on first connection on Play module:
After upgrade to VoiceGuide_7.3.1_120806.exe happens something strange.
Script is looping inside himself.
Loop happens only one time in script but in each one connection.
loop.zip
After install VG update script is making a loop on first connection on Play module:
130217.515 19 8 3 db completed. SqlQueryType=READER, RowsCount=1, sRv=
130217.515 19 8 3 db completed. iRunWait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0
130217.515 19 8 3 db completed. iRowsAffected=1
130217.515 19 8 3 FindNextVgmTitleInPathList: next module title is=[play powitanie projektu]
130217.515 19 8 3 RunModule_AddToTaskQueue [Play,[play powitanie projektu],504]
130217.515 19 8 3 q scr add evScriptEvent 9800 CMD_RUN_SAME_MODULE_AGAIN
130217.515 6 8 3 q scr run evScriptEvent sCode=[CMD_RUN_SAME_MODULE_AGAIN] iActionID=0, crn=0[0|0|0|0|0][|||||] 12|00:00:11.1562500
130217.515 6 8 3 scriptevent CMD_RUN_SAME_MODULE_AGAIN 0|0|0 || LineState=LS_DBQUERY
130217.515 6 8 3 t timer clear (force=False)
130217.515 6 8 3 RunModule start Play, [play powitanie projektu], iModuleIdx=504, previous: vgm=504, vgs=13:13
130217.515 6 8 3 [play powitanie projektu] VGMTYPE_PLAY run start
in this moment is looping
130217.515 6 8 3 answering the call (picking up the line)
130217.515 6 8 3 t timer clear (force=True)
130217.515 19 8 3 db odbc query completed.
130217.515 6 8 3 ktTel_AnswerCall_Enqueue source=AnswerTheCall
130217.515 6 8 3 q tel add cmd_AnswerCall [0,0,0,0,0][||||]
130217.515 6 8 3 ktTel_LineAnswerCall =>
130217.515 7 8 3 q tel run cmd_AnswerCall 6|00:00:00.3906250
130217.546 18 8 3 ev Dialogic 2050,GCEV_ANSWERED, crn=280030c, 2050,0,0,,,
130217.546 18 8 3 q scr add evScriptEvent 2050 GCEV_ANSWERED
130217.546 18 8 3 ev CallState GCEV_ANSWERED, crn=280030c, iEvent=2 ,256,1,4, s1:, s2:, s3:]. vgEngine v7.3.4601.33764 (2012-08-06 17:45:27.99)
130217.546 18 8 3 q scr add evCallState 2 GCEV_ANSWERED
130217.546 6 8 3 q scr run evScriptEvent sCode=[GCEV_ANSWERED] iActionID=0, crn=280030c[2050|0|0|0|0][|||||] 12|00:00:11.1562500
130217.546 6 8 3 scriptevent GCEV_ANSWERED 2050|0|0 || LineState=LS_MODULE_TRANSITION
130217.546 6 8 3 q scr run evCallState sCode=[GCEV_ANSWERED] iActionID=0, crn=280030c[256|1|4|0|0][|||||] 12|00:00:11.1562500
130217.546 6 8 3 LineEvCallState crn=280030c event=2|GCEV_ANSWERED iCallState=256 calldirection=1 gcCallState=4 [||]
130217.546 6 8 3 LineEvCallState eLineStateThisEvent=Connected, ScriptState=LS_MODULE_TRANSITION
130217.546 6 8 3 ls set Connected (scriptstate=LS_MODULE_TRANSITION)
130217.546 6 8 3 yLineStateAppPov: Connected crn=280030c,ev=2,GCEV_ANSWERED,1, sParam1=
130217.546 6 8 3 LineEvCallState LINECALLSTATE_CONNECTED begin
130217.546 6 8 3 Set_hCall crn=280030c, called from LINECALLSTATE_CONNECTED
130217.546 6 8 3 LineEvCallState_Connected_InBound begin
130217.546 6 8 3 Inband detection not enabled
130217.546 6 8 3 ScriptWorkingMode set Running_Normal, (called from LineEvCallState_Connected_InBound)
130217.546 6 8 3 StartLoadedVgs 1 : C:\Program Files\VoiceGuide\Scripts\Maciej\prepaid_2011_10_14.vgp (7.3.4601.33764 2012-08-06 17:45:27.99)
130217.546 6 8 3 d updtd PathVoiceGuide | C:\Program Files\VoiceGuide
130217.546 6 8 3 d updtd ScriptPath | C:\Program Files\VoiceGuide\Scripts\Maciej\
130217.546 6 8 3 d updtd ScriptsPath | C:\Program Files\VoiceGuide\Scripts\Maciej\
130217.546 6 8 3 d updtd PathScript | C:\Program Files\VoiceGuide\Scripts\Maciej
130217.546 6 8 3 set sScriptToRunOnHangup=[C:\Program Files\VoiceGuide\Scripts\Maciej\prepaid_temination_pro_15.vgp] in StartLoadedVgs
130217.546 6 8 3 rv add [$RV_STARTTIME]{2012-08-09 13:02:17}
130217.546 6 8 3 d updtd $RV_STARTTIME | 2012-08-09 13:02:17
130217.546 6 8 3 rv add [$RV_DEVICEID]{8}
130217.546 6 8 3 d updtd $RV_DEVICEID | 8
130217.546 6 8 3 rv add [DlgcVoice]{dxxxB1C3}
130217.546 6 8 3 d updtd DlgcVoice | dxxxB1C3
130217.546 6 8 3 rv add [DlgcNetwork]{dtiB1T3}
130217.546 6 8 3 d updtd DlgcNetwork | dtiB1T3
130217.546 6 8 3 rv add [$RV_CIDNAME]{}
130217.546 6 8 3 d updtd $RV_CIDNAME |
130217.546 6 8 3 rv add [$RV_DNIS]{222054699}
130217.546 6 8 3 d updtd $RV_DNIS | 222054699
130217.546 6 8 3 rv add [DNIS]{222054699}
130217.546 6 8 3 d updtd DNIS | 222054699
130217.546 6 8 3 rv add [iSDN_SETUP]{ l ! 222030034p 222054699}
130217.546 6 8 3 d updtd ISDN_SETUP | l ! 222030034p 222054699
130217.546 6 8 3 d updtd PathApp | C:\Program Files\VoiceGuide
130217.546 6 8 3 rv add [$RV_CIDNUMBER]{222030034}
130217.546 6 8 3 d updtd $RV_CIDNUMBER | 222030034
130217.546 6 8 3 t timer clear (force=False)
130217.546 6 8 3 RunModule start Evaluate, [sTART], iModuleIdx=94, previous: vgm=504, vgs=1:13
130217.546 6 8 3 state [sTART] Evaluate [now()]
130217.546 6 8 3 eval [now()]
130217.546 6 8 3 eval GetTypeFromProgID returned
130217.546 6 8 3 eval CreateInstance returned
130217.546 6 8 3 eval InvokeMember Language returned
130217.546 6 8 3 eval InvokeMember Eval returned
130217.546 6 8 3 eval ReleaseObject call
130217.546 6 8 3 rv add [sTART_Input]{now()}
130217.546 6 8 3 d added START_Input | now()
130217.546 6 8 3 d updtd START_Input | now()
130217.546 6 8 3 rv add [sTART]{2012-08-09 13:02:17}
130217.546 6 8 3 d added START | 2012-08-09 13:02:17
130217.546 6 8 3 d updtd START | 2012-08-09 13:02:17
130217.546 6 8 3 creating new (non-global) rv : call_start
130217.546 6 8 3 rv add [call_start]{2012-08-09 13:02:17}
130217.546 6 8 3 d added call_start | 2012-08-09 13:02:17
130217.546 6 8 3 d updtd call_start | 2012-08-09 13:02:17
130217.546 6 8 3 Eval Expr result:[2012-08-09 13:02:17] stored in RV[call_start]
130217.546 6 8 3 path {2012-08-09 13:02:17} not found
and now properly
130218.343 4 8 3 db completed. SqlQueryType=READER, RowsCount=1, sRv=
130218.343 4 8 3 db completed. iRunWait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0
130218.343 4 8 3 db completed. iRowsAffected=1
130218.343 4 8 3 FindNextVgmTitleInPathList: next module title is=[play powitanie projektu]
130218.343 4 8 3 RunModule_AddToTaskQueue [Play,[play powitanie projektu],504]
130218.343 4 8 3 q scr add evScriptEvent 9800 CMD_RUN_SAME_MODULE_AGAIN
130218.343 4 8 3 db odbc query completed.
130218.343 6 8 3 q scr run evScriptEvent sCode=[CMD_RUN_SAME_MODULE_AGAIN] iActionID=0, crn=0[0|0|0|0|0][|||||] 12|00:00:11.1562500
130218.343 6 8 3 scriptevent CMD_RUN_SAME_MODULE_AGAIN 0|0|0 || LineState=LS_DBQUERY
130218.343 6 8 3 t timer clear (force=False)
130218.343 6 8 3 RunModule start Play, [play powitanie projektu], iModuleIdx=504, previous: vgm=504, vgs=13:13
130218.343 6 8 3 [play powitanie projektu] VGMTYPE_PLAY run start
130218.343 6 8 3 CheckForAnyPlayActionsAndSetkeysIfNecessary no PlayActions, vgmidx=504, strPaths=on {timeout 0} goto [komunikat_eventowy]
130218.343 6 8 3 PrepareAndPlayWavAndTts start iModuleIdx=504, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
130218.343 6 8 3 rv replace start [\$RV[manager]\$RV[id_proj_1_1]01.wav]
130218.343 6 8 3 rv replace end [\manager4\52001.wav]
130218.343 6 8 3 PrepareAndPlayWavAndTTS sPlayFile=\manager4\52001.wav
130218.343 6 8 3 state [play powitanie projektu] Playing wav (\manager4\52001.wav)
130218.343 6 8 3 FindSoundFile start [\manager4\52001.wav]
130218.343 6 8 3 q tel add cmd_PlayStart 823875 ,C:\Program Files\VoiceGuide\Scripts\manager\\manager4\52001.wav []
130218.343 7 8 3 q tel run cmd_PlayStart 6|00:00:00.3906250
130218.359 6 8 3 play start ok, playId=823875
Can you please post a more complete trace that covers the entire call from the time it was offered.
Please .ZIP up traces before posting.
I found command witch start loop in running script:
092447.687 6 5 2 answering the call (picking up the line)
but it happens only one time in connection.
After this command script backing up to start and then working properly no second answering the call command in this connection.
One more difference between old and new VG is: on line status windows in status cell showing durring dial out " Waiting for a call ... Ringing" and before update it was "Calling numer XXX XXX XXX ..."
and then Calling numer XXX XXX XXX ... Ringing ..." it helps to trace processes.
Please update system to this version of VoiceGuide:
[old link deleted]
If you still encounter the 'script restart on answer' issue then please post traces as before.
