Wav To Mp3 Convertion
After call recording I convert wav file to mp3 with Run Program Module:
c:\callrecord\ffmpeg.exe -i c:\callrecord\$RV[session_id].wav c:\callrecord\$RV[manager]\$RV[session_id].mp3
but sometimes (now 3-rd time) application is showing popup window error opening many windows and so killing server resources.
events log show:
Typ zdarzenia: Informacje
Źródło zdarzenia: Application Popup
Kategoria zdarzenia: Brak
Identyfikator zdarzenia: 26
Data: 2012-08-06
Godzina: 10:54:38
Użytkownik: Brak
Komputer: SISTI_115
Opis:
Podręczne okno aplikacji: ffmpeg.exe - Błąd aplikacji : Aplikacja nie została właściwie zainicjowana (0xc0000142). Kliknij przycisk OK, aby zakończyć aplikację.
Aby znaleźć więcej informacji, zobacz http://go.microsoft.com/fwlink/events.asp w Centrum pomocy i obsługi technicznej.
I think is because in the same time VG try to convert wav file to mp3 sometimes crashing ffmpeg application.
Have You alternative to converting wav to mp3 or wav/mp3 player online to web site?
Looks like the problem is with 3rd party program that you are calling, not with VoiceGuide.
As the problem is with 3rd party app then you should contact supplier/support to that 3rd party app.
If you would like us to provide a VoiceGuide Extension/module that can perform the functionality that you require then please contact sales@voiceguide.com
How to detect, that call was recorded (detecting wav file)?
I think that my problem is because log shows that no wav file was detected.
How to detect that a certain file exists on system?
There is a ".FileExists" function in VBScript
Set objFSO = CreateObject("Scripting.FileSystemObject")
If objFSO.FileExists (FILE3) then
end if
can you to help me write file checker?
my vbs:
If objFSO.FileExists ("C:\callrecord\ID2012082012314850.wav") then
msgbox "file exist!"
Else
msgbox "no file found"
end if
how to change it to VG acceptable?
no msgbox needed but variable: 1 - exists, 0 no found.
If objFSO.FileExists ("\folder\$RV[recorded_file].wav") then
fileexistschecker= "1"
Else
fileexistschecker="0"
end if
msgbox fileexistschecker
it's working, but how to put it to VG get fileexistschecker as variable?
You can use Run_ResultReturn API function to return a Result Variable to VoiceGuide.
eg:
Else
end if
vg.Run_ResultReturn $RV_LINEID, "[CheckRecordFileExists]{" & fileexistschecker & "}"
set vg = Nothing
in VoiceGuide script the $RV[CheckRecordFileExists] then has value of 0 or 1
See:
http://www.voiceguide.com/vghelp/source/html/com_run_resultreturn.htm
