Speech Vs Voice
I am obliged to upgrade my IVR because of Windows 7 64 bits. I simply want the TTS solution. Do i need a Voice board or a Speech board ? I intend to buy the D/4PCIU board. is it correct ?
Otherwise, can i use HMP software ?
Thanks for your help.
You do not need the 'Speech' board to use TTS. D/4PCIU is fine.
You can also use HMP if you would like to deploy a VoIP system.
